Genright Fenders at JeepHut - JeepForum.com
post #1 of 8 Old 02-26-2013, 05:48 PM Thread Starter
JeepHut
This is the ALUMINUM Tube Front fender flares from GenRight Off Road for the Jeep JK.
These tube fenders are perfect for rock crawling through the Boulders or Trees on your favorite trail.
Want to go with bigger tires? We have also opened the wheel well to better clear those new bigger tires you want to buy too.
FEATURES:
Made of lightweight & durable 6061 Aluminum alloy.
Bolts on in same location as stock flare.
4" wide flare (same as stock).
Bigger wheel opening (up and rearward) to prevent tire rubbing.
1/8" thick laser cut and CNC bent plate and tubes will hold up out on the trail.
Built from rugged 1-1/2" diameter x .188" wall tubing.
TIG Welded in a precision jig to assure a good fit.
Includes new hardware (some stock hardware is reused).
Retains your stock inner fender well.
Includes detailed installation instructions.
100% made in USA!
Why pay more from a competitor? We are the company that pioneered trail tough aluminum tube fenders!
NOTES:
Fenders are sold in pairs.
Sold un-painted.
LED Side marker light kits are also available.
Installation requires minor drilling of the factory mounting locations.
Click on More Pictures to see larger more detailed images.
How strong are GenRight Fenders? Watch this customer submitted test to find out:
JeepHut is offline
post #2 of 8 Old 02-26-2013, 05:50 PM Thread Starter
JeepHut
These close fitting tube fenders are perfect for rock crawling through the Boulders or Trees on your favorite trail.
FEATURES:
1/8" thick laser cut and CNC bent plates and tubes will hold up out on the trail.
100% made in USA!
NOTES:
Sold un-painted.
Also available in a steel version.
Click on More Pictures to see larger more detailed images of this product.
JeepHut is offline
post #3 of 8 Old 02-28-2013, 08:49 PM Thread Starter
JeepHut
We now offer the entire line.
706-692-5488
JeepHut is offline
post #4 of 8 Old 03-03-2013, 09:37 AM Thread Starter
JeepHut
Thanks for the orders
706-692-5488
JeepHut is offline
post #5 of 8 Old 03-07-2013, 11:25 PM Thread Starter
JeepHut
all pms have been responded to.
Thanks for the business.
Mike
Jeephut.com
706-692-5488
706-692-5488
JeepHut is offline
post #6 of 8 Old 09-15-2013, 12:19 PM Thread Starter
JeepHut
Give us a call for a great deal on Genright products
706-692-5488
JeepHut is offline
post #7 of 8 Old 09-15-2013, 11:51 PM
timpane
thank you very much for this valuable information. it's really helpful. Keep updating us
act prep test
timpane is offline
post #8 of 8 Old 09-16-2013, 07:12 AM Thread Starter
JeepHut
This is the GenRight Off Road FULLY WELDED replacement roll cage kit for your Jeep TJ, YJ or CJ-7.
This is the BEST most protective cage for you and your family you can put in your Jeep!
These cages are JIG welded at the GenRight factory and shipped to you by truck on a pallet.
FEATURES:
MIG Welded in a production Jig to assure fit.
Made from heavy wall D.O.M. (Drawn Over Mandrel) seamless tubing.
All the mounting brackets are 3/16" thick Laser Cut and CNC formed.
Does NOT require cutting the dash.
6 point mounting.
Includes 3 grab handles, as pictured.
Includes all the factory seat belt mounting brackets.
Designed for maximum visibility.
Works with factory hard top (optional factory soft top adaptor kit is available).
Can be used with factory hard or soft doors.
Head room for rear seat passengers too!
NOTES:
This 100% replaces the factory roll bar, it will require removing some of the interior ot install.
Cage is welded and ready for powder coating.
Factory soft top requires a optional adapter kit to re-mount the factory door surrounds. If you plan to reuse the factory soft top the Sport Cage may be a better choice.
Customers can also pick up the cage here at the factory.
706-692-5488
JeepHut is offline
You may not post new threads
