GenRight 4-Link Rear Kit With Links - JeepForum.com
post #1 of 1 Old 10-31-2012, 12:09 PM Thread Starter
BROTHERS4X4
Part# SUP-4101
Fits Jeep :TJ, YJ, CJ, Early Bronco or Toyota;GenRight has figured out all the mounting points for proper geometry (weight transfer, rear steer and minimal anti-squat, etc.) to make your rig a top notch crawler with awesome articulation AND handle great on the street too! The main frame control arm mounts are pre-welded to a "C" section of steel to beef up the frame and help distribute the load. You simply slip each mount over the frame and weld them in place! The kit is designed to attach to the frame next to your stock (or aftermarket) transfer case skid plate. This rear kit is also perfect for moving your rear axle back, stretching your wheelbase to the Magic 100"+ when used with our EXT or COMP gas tanks. For you guys converting from leaf springs, you can say goodbye to axle wrap and all the issues associated with it! It will be power to the ground and high clearance from now on.
*Heavy Duty 1/4 & 3/16" thick laser cut and CNC bent frame side control arm mounts.
*Laser cut and CNC bent upper and lower control arm mounts for the rear axle.
*2" x .120 thick wall DOM tubing for the lower control arms.
*1-3/4" x .120 thick wall DOM tubing for the upper control arms.
*Left and right hand machined bungs to weld into the control arms for easy adjustment.
*Genuine Currie forged 1-1/4" shank Johnny Joints, at both ends of the control arm.
*Grade 8 mounting hardware
*Installation instructions.
$1000 Shipping Not Included
Call for more info. (909)730-9956 or (909)445-8220
... WE DO REAR ENDS ...
BROTHERS4X4 is offline
4-link , gen-right , jeep , offroad , rear
You may not post new threads
