Gen-Right Rear Sway Bar Kit For YJ / TJ / LJ - JeepForum.com
post #1 of 1 Old 10-22-2012, 05:48 PM Thread Starter
BROTHERS4X4
This is the GenRight ""hollow"" rear sway bar kit to fit a Jeep TJ, LJ or YJ. These are great to add stability to your lifted or long travel vehicle. Our sway bar is about 30% stiffer than other brand Anit-Rock type sway bars and the ends are reinforced for durability off-road.These sway bars are custom made by GenRight to fit the width of a Jeep frame and survive up to 16"" travel shocks (when properly mounted). This is the type of sway bar that you leave connected all the time, on-road AND off-road.
Part# SWB-1003
* NOTE: This kit requires drilling, cutting and welding to properly mount it.
*Sway Bar
*Rear
*Hollow
*16" long Solid Steel arms
*1-1/4" diameter splined bar
*CNC machined sway bar bushings
*Adjustable heims at both ends of the links
*Tabs to mount the bar on frame
*Double shear tabs to weld on the axle
*All the proper mounting hardware
*Installation instructions and diagrams
$470.00 Not Including Shipping
... WE DO REAR ENDS ...
BROTHERS4X4 is offline
crawl , gen-right , jeep , offroad , rock crawling
You may not post new threads
