Gear Swap install special! Ends March 31st - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Gear Swap install special! Ends March 31st
JKS Flex Connect in Actions!CCOR is Hiring! Athens, GA!ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 03-10-2015, 09:48 AM   #1
CCOR
Vendor
1979 CJ5
From now until the end of March we will be having a gear install special at Classic City Off Road. Bring us your Jeep to get top quality Yukon gears and install kits installed here in Athens GA
Prices include install kits, ring and pinions, gear oil, labor, and tax all included.
JK Non Rubicon's start at $1119 Installed for 4.56, 4.88, or 5.13's
JK Rubicon's start at $1189 installed with 4.56, 4.88, 5.13, or 5.38's
TJ's start at $1370 for 4.56 or 4.88
TJ Rubicon's are $1499 for 4.56, 4.88, or 5.13
YJ's start at $1430
Other Jeep model's will need to post up or call to get a quote
JK's with 3.21 gears will need a new carrier for the front which is $69.99
and 2012 + will need spider gears which are also $69.99
TJ's and YJ's with 3.54 and down gears will also need a new carrier for the front which is $69.99
A rear carrier is needed in Model 35 rear axles if you have 3.08 gears. $115
A rear carrier is need in Dana 44 rears if you have 3.73 or lower gears. $65
2012 + JK's with automatic's will need a AEV Procal module which is $159
Call 855-572-GEAR to setup your appointment!
www.classiccityoffroad.com
To order call 706-559-9609
Randy's Gear Supply
CCOR is offline   Reply With Quote Quick reply to this message
