Gear Packages Available! Your # 1 Diff Shop is ROCKRIDGE 4WD Just 1 Click Away! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Gear Packages Available! Your # 1 Diff Shop is ROCKRIDGE 4WD Just 1 Click Away!
Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinLedlight bar light locks @ oconee off road 706 534 9955Don't forget the Jeep Forum discount, 10% off!
Unread 06-24-2014, 05:13 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
ROCKRIDGE 4WD IS SIMPLIFYING THE WAY YOU BUY GEARS!
Basic Gear Packages Starting at $449
These kits include Front and Rear Ring and Pinions. They are only with "Mini Install Kits" So if you are NOT a shop and do NOT have bearings or Necessity parts at hand then you will need the kit below!
Mast Gear Packages Starting at $524.99
These kit's include the Front and Rear Ring and Pinions. With Front and Rear Master Install Kits. These Master Kits will have all the necessary components to CORRECTLY install your gears.
These kit's do not include Carrier's. If your re-gearing you need to know your current gear ratio as some carrier's has breaks in them that won't allow you to run "Numerically Higher" Gears.
ROCKRIDGE 4WD has you pick your VEHICLE, BRAND, if you need a CARRIER, Choose your CURRENT GEAR RATIO, pick your new RATIO, What type of FRONT AXLE you have, and what type of REAR AXLE you have, along with the year of your Model of vehicle.
We have packages available for brands:
CLICK ON YOUR VEHICLE BELOW:
Jeep Wrangler JK 2012 + 3.6L
Jeep Wrangler JK 07-2011 3.8L
Jeep Wrangler TJ / LJ 97-06
Jeep Wrangler YJ 87-95
Jeep Cherokee XJ 84-01
Jeep Comanche MJ 1986-92
Also available for Jeep Grand Cherokee's WK and Commander's XK in 4.10 Ratio Exclusively made by Nitro and brought to you by ROCKRIDGE 4WD.
***These are not on our site yet, if you are interested you will need to email me directly! See below***
Still can't figure it out? No worries. Just email me direct at Erin@Rockridge4wd.com with what you after and brand. I will get you taken care of!
Jeff@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is online now   Reply With Quote
Unread 07-02-2014, 05:10 PM   #2
Rockridge4WD
Vendor
2010 JK Wrangler
Looking to re-gear?! We've made it EASY by putting together these complete gear change packages!
Contact me direct and we will make it happen! Joel@rockridge4wd.com
[ATTACH]
1449466
[/ATTACH]
Unread 08-08-2014, 01:56 PM   #3
Rockridge4WD
Vendor
2010 JK Wrangler
Just buy your Jeep? Looking to give it more power? Rockridge 4wd our your Diff experts. We will get you set up with your Gears, Axles and Lockers to get your jeep back in the hills wheeling! contact us today for your very own quote!
Derran@rockridge4wd.com
Like Us On FACEBOOK --> www.Facebook.com/rockridge4wd
Unread 08-12-2014, 04:53 PM   #4
Rockridge4WD
Vendor
2010 JK Wrangler
Just Buy that Jeep and Need to regear it? Don't wait let Rockridge 4wd get you into a gear and Locker set up with will best fit you and your Jeep! Contact Rockridge 4wd today for your very own quote!
Unread 08-18-2014, 05:10 PM   #5
Rockridge4WD
Vendor
2010 JK Wrangler
Just lift your jeep and Notice that you need to rear gear and put lockers in it? Let Rockridge 4wd get you into the correct gears, lockers for you and your Application! Contact us today for your very own quote!
