Ford Explorer 8.8 4340 Chromoly Axle Shaft Kit C Clip Eliminator Kit 5x4.5 and 5x5.5 - JeepForum.com
post #1 of 164 Old 07-12-2011, 11:45 AM Thread Starter
Baseline 4x4
Baseline 4x4's Avatar
1979 CJ5
The perfect upgrade for any 97-06 Jeep TJ Wrangler, 87-95 Jeep YJ Wrangler or 84-01 Jeep XJ Cherokee. Instock and shipping now.
Ford 8.8 Ultimate Axle Shaft kit 95-02 Ford Explorer, 4340 CHROME-MOLY, C-Clip Eliminator, 31 Spline( DOUBLE DRILLED) 5x4.5 pattern and 5x5.5 patterns. Yukon 4340 Chrome Moly alloy axles offer a strength increase over stock while retaining a low cost. Yukon 4340 Chrome Moly alloy rear axles come with a one year warranty against manufacturing defects. This is a Ford 8.8 31 spline axle kit with 4340 shafts that bolt in instead of using the stock style C-Clips.
Features:
C-clip eliminator system using Timken Set-20 bearings
Double drilled 4340 axles, 31-spline (5x5.5 and 5x4.5)
They increase the track width of the Explorer housing 1-inch per side. (Explorer’s are 1.75” narrower than a Jeep YJ/TJ/XJ housing)
No welding (cutting is involved on the housing)
Screw in studs (studs supplied, -20 sized)
Fits with factory disc brake assemblies.
Fits:
95-02 Ford Explorer with 31 Spline 8.8 Rear Axle
YA WF88-31-KIT - Ford 8.8 Ultimate Axle Shaft kit 95-02 Ford Explorer, 4340 CHROME-MOLY, C-Clip Eliminator, 31 Spline
Baseline 4x4 Outfitters
Baseline 4x4 is offline
post #2 of 164 Old 07-17-2011, 05:50 AM Thread Starter
Baseline 4x4
1979 CJ5
Chromoly shafts for the Ford 8.8 Rear Axle from Yukon Gear. Strength and performance all in one kit.
post #3 of 164 Old 07-29-2011, 08:24 AM Thread Starter
Baseline 4x4
1979 CJ5
Stength and performance when you need it from Yukon Gear
post #4 of 164 Old 07-29-2011, 08:42 AM
97 ZJ Steve
PM me with a price shipped to 08724 NJ plz
-Steve
97 ZJ Steve is offline
post #5 of 164 Old 07-29-2011, 09:01 AM Thread Starter
Baseline 4x4
1979 CJ5
PM Sent. Let me know if you need any additional information.
post #6 of 164 Old 08-08-2011, 08:25 PM Thread Starter
Baseline 4x4
1979 CJ5
4340 Chromoly Axle Kit for the Ford 8.8 Axle are now in stock and can be processed for shipment immediately.
post #7 of 164 Old 08-08-2011, 08:53 PM
connor0770
These will hold up to 37's relatively well correct? And do you sell the shafts separate?
97 TJ Dana 30 w/ARB Solid Cover, Currie 4" lift, Ford 8.8 w/ Riddler Cover, Currie Steering, Trail Gear Front Bumper, LOD Rear Tire Carrier, Smittybuilt XRC8, 35" KM2's, 5100 Bilsteins, Teraflex Oil Pan Skid, Poison Spider Sliders, Rock Lights etc.
connor0770 is offline
post #8 of 164 Old 08-08-2011, 08:55 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
It'll laugh at 37s
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #9 of 164 Old 08-19-2011, 02:17 PM Thread Starter
Baseline 4x4
1979 CJ5
Yes the shafts any components are available separately. Yukon doesn't see 37's being a problem with these shafts.
post #10 of 164 Old 08-23-2011, 06:52 AM Thread Starter
Baseline 4x4
1979 CJ5
Yukon Gear 4340 Chromoly Axle Shafts come with a lifetime warranty
post #11 of 164 Old 08-25-2011, 11:45 AM Thread Starter
Baseline 4x4
1979 CJ5
This Axle Kit from Yukon Gear comes with a lifetime warranty on the 4340 chromoly axle shafts
post #12 of 164 Old 09-06-2011, 02:32 PM Thread Starter
Baseline 4x4
1979 CJ5
great upgrade for the Ford 8.8 Rear Axles
post #13 of 164 Old 09-08-2011, 06:20 AM Thread Starter
Baseline 4x4
1979 CJ5
All Yukon Gear Chromoly Axles come with a lifetime warranty.
post #14 of 164 Old 09-22-2011, 12:37 PM Thread Starter
Baseline 4x4
1979 CJ5
Ford 8.8 C Clip Eliminator Kit from Yukon Gear. Strength and performance at an affordable price.
post #15 of 164 Old 09-24-2011, 12:03 PM Thread Starter
Baseline 4x4
1979 CJ5
The Ford 8.8 is an excellent choice when considering an axle upgrade
You may not post new threads
