-   Vendor Display (http://www.jeepforum.com/forum/f43/)
-   -   Ford Explorer 8.8 4340 Chromoly Axle Shaft Kit C Clip Eliminator Kit 5x4.5 and 5x5.5 (http://www.jeepforum.com/forum/f43/ford-explorer-8-8-4340-chromoly-axle-shaft-kit-c-clip-eliminator-kit-5x4-5-5x5-5-a-1238720/)
Baseline 4x4 07-12-2011 11:45 AM
The perfect upgrade for any 97-06 Jeep TJ Wrangler, 87-95 Jeep YJ Wrangler or 84-01 Jeep XJ Cherokee. Instock and shipping now.
Ford 8.8 Ultimate Axle Shaft kit 95-02 Ford Explorer, 4340 CHROME-MOLY, C-Clip Eliminator, 31 Spline( DOUBLE DRILLED) 5x4.5 pattern and 5x5.5 patterns. Yukon 4340 Chrome Moly alloy axles offer a strength increase over stock while retaining a low cost. Yukon 4340 Chrome Moly alloy rear axles come with a one year warranty against manufacturing defects. This is a Ford 8.8 31 spline axle kit with 4340 shafts that bolt in instead of using the stock style C-Clips.
Features:
C-clip eliminator system using Timken Set-20 bearings
Double drilled 4340 axles, 31-spline (5x5.5 and 5x4.5)
They increase the track width of the Explorer housing 1-inch per side. (Explorer’s are 1.75” narrower than a Jeep YJ/TJ/XJ housing)
No welding (cutting is involved on the housing)
Screw in studs (studs supplied, -20 sized)
Fits with factory disc brake assemblies.
Fits:
95-02 Ford Explorer with 31 Spline 8.8 Rear Axle
http://www.baseline4x4.com/images/pr...0_Axle_Kit.jpg
YA WF88-31-KIT - Ford 8.8 Ultimate Axle Shaft kit 95-02 Ford Explorer, 4340 CHROME-MOLY, C-Clip Eliminator, 31 Spline
Baseline 4x4 07-17-2011 05:50 AM
Chromoly shafts for the Ford 8.8 Rear Axle from Yukon Gear. Strength and performance all in one kit.
Baseline 4x4 07-29-2011 08:24 AM
Stength and performance when you need it from Yukon Gear
97 ZJ Steve 07-29-2011 08:42 AM
PM me with a price shipped to 08724 NJ plz
:highfive:
-Steve
Baseline 4x4 07-29-2011 09:01 AM
PM Sent. Let me know if you need any additional information.
Baseline 4x4 08-08-2011 08:25 PM
4340 Chromoly Axle Kit for the Ford 8.8 Axle are now in stock and can be processed for shipment immediately.
connor0770 08-08-2011 08:53 PM
These will hold up to 37's relatively well correct? And do you sell the shafts separate?
EugeneTheTJ 08-08-2011 08:55 PM
It'll laugh at 37s
Baseline 4x4 08-19-2011 02:17 PM
Yes the shafts any components are available separately. Yukon doesn't see 37's being a problem with these shafts.
Baseline 4x4 08-23-2011 06:52 AM
Yukon Gear 4340 Chromoly Axle Shafts come with a lifetime warranty
Baseline 4x4 08-25-2011 11:45 AM
This Axle Kit from Yukon Gear comes with a lifetime warranty on the 4340 chromoly axle shafts
Baseline 4x4 09-06-2011 02:32 PM
great upgrade for the Ford 8.8 Rear Axles
Baseline 4x4 09-08-2011 06:20 AM
All Yukon Gear Chromoly Axles come with a lifetime warranty.
Baseline 4x4 09-22-2011 12:37 PM
Ford 8.8 C Clip Eliminator Kit from Yukon Gear. Strength and performance at an affordable price.
Baseline 4x4 09-24-2011 12:03 PM
The Ford 8.8 is an excellent choice when considering an axle upgrade
The time now is 12:27 PM.
