END OF THE WORLD CHASSIS SAVER 2 for 1 BLOWOUT! - JeepForum.com
post #1 of 2 Old 12-20-2012, 09:45 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
End Of The World Sale Starts Now!
BUY 1 GET 1 FREE CHASSIS SAVERô
Now thru Sunday 12-23-12
Available Only Online - Not Available in Stores
For anyone not familiar with this product, CHASSIS SAVERô is a direct replacement for POR-15 at up to 45% lower cost.
We have been manufacturing CHASSIS SAVERô for almost 20 years and it has been proven under the harshest conditions.
In addition to the auto restoration market, more than 500 townships, public works departments and DOT fleet maintenance
facilities use CHASSIS SAVERô for protection of snow and ice removal equipment, highway, off road and general vehicle maintenance.
Valid thru Sunday 12/23 at Midnight
all CHASSIS SAVERô Quarts and Gallons will be sold 2 for 1
Buy 1 Quart CHASSIS SAVERô Get 1 Quart FREE - Coupon Code: CSQT-B1G1F
(1 Quart price $37.50) Choose 2 of same color/finish or 2 different
Buy 1 Gallon CHASSIS SAVERô Get 1 Gallon FREE - Coupon Code: CSGL-B1G1F
(1 Gallon price $104.75) Choose 2 of same color/finish or 2 different
To get the free item, YOU MUST PUT 2 ITEMS INTO YOUR CART FIRST AS IF YOU ARE BUYING BOTH, THEN
APPLY THE COUPON CODE AND WATCH A DISCOUNT APPEAR FOR THE FULL PRICE OF 1 OF THE ITEMS
Standard UPS shipping rates apply - $11.00 for 2 Quarts, $17.00 for 2 Gallons
Place Orders Here @ www.shop.monstaliner.com
Colors/Finishes available are as follows:
UCP99 Gloss Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an
automotive grade synthetic, acrylic or urethane enamel.
UCP934 Silver-Aluminum - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoating is not needed unless change of color is desired.
UCP98 Floor & Machine Gray - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an automotive grade
synthetic, acrylic or urethane enamel. Makes an outstanding, chemical and abrasion resistant coating for shop and industrial floors.
UCP970 Antique-Satin Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Note: Use of gloss black is recommended if you know ahead of time you are going to topcoat.
Note: Chassis Saverô can be topcoated with itself or any other solvent base coating within 24 hours with no additional surface prep.
After 24 hours scuff sanding is required.
Please see Technical Data Bulletin link below for complete directions on surface preparation and application.
CHASSIS SAVERô Tech Bulletin
CHASSIS SAVERô Material Safety Data Sheet
Further Details:
The Coupon Codes above ARE NOT COMBINABLE
If you want to purchase more than 1 set of Quarts or Gallons you can do so by just completing
your first order and then going back to place another order. Do so as many times as you like.
This offer is a stand-alone promotion and can not be combined with any other Magnet products or MONSTALINERô purchases
Please post any questions regarding the promo to the thread so others who have similar questions can read the conversation.
PM's are OK too. I'm just trying to cut down on answering similar questions many times.
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #2 of 2 Old 12-21-2012, 08:58 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Is it over yet?
You may not post new threads
