Deep discounts on Posi loks kits
Pm for prices
PSL100 SHIFT FORK CAST IRON
PSL1100 PERM LOCK KIT D30 YJ, XJ
PSL900 POSI-LOK YJ 87-95
PSL920 POSI-LOK FOR 3-6 INCH RAISED
* 1987-95 YJ Wrangler
* 1984-93 XJ Cherokee
* 1986-92 MJ Comanche
* With front axle disconnect
YJ Wranglers 1987-95 and Cherokees, 1984-91 utilize a vacuum actuated front axle unit, often referred to as a front axle disconnect. Some argue this sytem has made engaging four wheel drive easier, however it has not come without complications. When the transfer case shifter is engaged into four wheel drive, vacuum supplied from the engine travels through air lines running from the transfer case to a fork assembly on the axle housing. This vacuum slides a shift collar inside the axle tube, engaging the passenger side axle shaft to achieve four wheel drive. Problems with this engagement arise from vacuum leaks, worn out transfer case vacuum switches, plugged vacuum lines, vacuum line damage, and vacuum actuator internal failure, among others. The Posi-Lok eliminates all these potential problems with a manual cable operated front axle engagement system.
Pm for prices
