Dana 44 axle truss - JeepForum.com
post #1 of 1 Old 06-29-2012, 06:05 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Dana 44 axle truss
RUBICON DANA 44 REAR AXLE TRUSS
Artec Industries is excited to announce the NEW Dana 44 Rear Axle Truss for Jeep Rubicon axles. This heavy duty truss system is designed to take serious abuse and reinforce your entire axle while also providing a flat surface to mount your upper links. The 1/4" thick truss top incorporates a unique design to strengthen both the axle and provide a low profile link mounting surface. The base truss itself spans about 43.5 inches across the center of your axle.
The Jeep Rubicon Rear Dana 44 has a centered differential housing that measures aprox. 15" and the axle tube diameter is 2.625 inches. Other Dana 44's will measure differently and have differing axle tube diameters. Please ensure your axle meets these dimensions prior to ordering. Can be easily modified to fit larger tube diameters.
Features include:
•1/4" thick mild steel truss. Precision CNC cut and bent for great fitment.*
•Truss is low profile allowing link joints to be mounted with ideal geometry - about 8 inches from the axle centerline.
•Truss spans entire length of axle aprox. 43.5" - not just for mounting links.
•Truss is reinforced using interlocked 1/4 thick gussets for maximum strength and easy assembly.
•Overall low profile design means your axle is stronger, sleaker, easier to fit into any vehicle, and less likely to interfere with vehicle components.
NOTE: This kit requires general welding and fabrication skills. Welding should only be done by a competent welder. Artec Industries implies no guarantees or warranties and is not liable for improper installation.
*Some grinding and fitment may be required when installing this kit. Every axle varies slightly and some fabrication may be required. May require brake line relocation to fit.
ARTEC INDUSTRIES
1-855-ARTEC99
Jeepforum COUPON: jeepforum
Follow us on
Quick Links:
ARTEC is offline
Barnes 4wd Axle Truss Barnes4wd Vendor Display 56 01-12-2012 11:44 AM
You may not post new threads
