Dana 30 Truss for your TJ, LJ, ZJ, and XJ - JeepForum.com
post #1 of 58 Old 12-21-2012, 10:46 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
We just put this up online...
Taking Preorders now. The kit comes with a set of new polyurethane bushings for your UCA which can be upgraded to Currie Johnny Joints. We also sell the truss by itself without bushings if you plan on not using your passenger side UCA.
For the TJ, LJ, ZJ, click HERE.
For the XJ high pinion version, click HERE
Here are some install pics.
LINK
ARTEC INDUSTRIES
1-855-ARTEC99
Jeepforum COUPON: jeepforum
Follow us on
Quick Links:
ARTEC is offline
post #2 of 58 Old 12-27-2012, 11:51 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Time to stiffen up that front end.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #3 of 58 Old 12-28-2012, 09:52 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
All painted up.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #4 of 58 Old 01-16-2013, 10:10 AM
FKemp3
Have an ETA on when these will be shipping?
FKemp3 is offline
post #5 of 58 Old 01-16-2013, 02:18 PM
aparke4
Currie add on includes both uppers of just passenger upper?
aparke4 is offline
post #6 of 58 Old 01-16-2013, 03:10 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Any clearance issues?
2016 TJ of the Year
Founder, Offroad NC
Follow our journey:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
EugeneTheTJ is offline
post #7 of 58 Old 01-16-2013, 05:39 PM
cheftrail
how much?
cheftrail is offline
post #8 of 58 Old 01-17-2013, 11:11 AM
aparke4
Pre order full truss with currie option is 225 with no forum codes added... Not sure what retail will be after the ore order time is up.
aparke4 is offline
post #9 of 58 Old 01-17-2013, 12:18 PM
RDaniel2405
RDaniel2405's Avatar
Online I see that ARTEC makes a 8.8 swap kit w/ truss for a TJ. But Ive been waiting for a company to make a Truss/Swap kit for front and rear JK 44's to a TJ... Maybe someone already makes one, I dont know. Im going to search online after I post this.
MY DAILY DRIVER BUILD
WTB Impact Orange half doors.
RDaniel2405 is offline
post #10 of 58 Old 01-20-2013, 08:43 AM
aparke4
I think the 8.8 and 44 chunk are pretty similar in size as well as the tubes- maybe with some love the 8.8 kit would fit? Might be worth asking... The Jk is wider though wms to wms.
aparke4 is offline
post #11 of 58 Old 01-20-2013, 10:26 AM
RDaniel2405
For some one like me with dana 30/35 there would be a lot of advantages. I have read online that some people have done front and rear jk axles for less than $2000
- The axle tubes are longer, wider, and thicker then the TJ axle tubes, axle truss will make it stronger. A Unlimited JK weighs over 1000lbs more than a standard TJ
- Much stronger ring and pinion
- Steering components and knuckles are beefier
- The JK Rubicon axles are 32 spline, the JK non-rubi axles are 30 spline vs the 30 spline TJ Rubi axles.. or even the 27 spline D35 and D30 TJ axles
- The front JK axles are high pinion vs the standard LP TJ axles.
- Larger brake components (rotors, calipers, pads) available at any parts store. Disc brake upgrade with OEM parts if going form TJ35 to JK44
post #12 of 58 Old 02-13-2013, 11:17 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
If you are thinking about getting some of ours parts, NOW would be a great time to do it. 15% off all ARTEC made products but HURRY, its over after Friday.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #13 of 58 Old 02-13-2013, 11:29 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Hi Nate
A friend of mine just received one of these trusses that we will be installing in his XJ soon. He came by yesterday to show it to me. Nice stuff!
Joe Dillard is offline
post #14 of 58 Old 02-13-2013, 04:35 PM
slmason72
Call for availability? I already have the Currie joints for the axle ends of the UCA. Any reason not to cut the passenger side to length and weld it to the top of the truss? Keyholes could be used for bottom/reinforcement welds... Might have to disassemble the JJ to weld it...
slmason72 is offline
post #15 of 58 Old 02-13-2013, 10:11 PM
Joe Dillard
That's our plan on my friends.
You may not post new threads
