-   Vendor Display (http://www.jeepforum.com/forum/f43/)
-   -   Dana 30 Truss for your TJ, LJ, ZJ, and XJ (http://www.jeepforum.com/forum/f43/dana-30-truss-your-tj-lj-zj-xj-1453118/)
ARTEC 12-21-2012 09:46 PM
We just put this up online...
https://artecindustries.3dcartstores.../tj-truss1.jpg
Taking Preorders now. The kit comes with a set of new polyurethane bushings for your UCA which can be upgraded to Currie Johnny Joints. We also sell the truss by itself without bushings if you plan on not using your passenger side UCA.
For the TJ, LJ, ZJ, click HERE.
For the XJ high pinion version, click HERE
Here are some install pics.
http://sphotos-b.xx.fbcdn.net/hphoto...81936084_n.jpg
http://sphotos-a.xx.fbcdn.net/hphoto...68444647_n.jpg
http://sphotos-a.xx.fbcdn.net/hphoto...65010002_n.jpg
LINK
ARTEC 12-27-2012 10:51 AM
Time to stiffen up that front end.
ARTEC 12-28-2012 08:52 AM
All painted up.
http://sphotos-a.xx.fbcdn.net/hphoto...24530420_o.jpg
FKemp3 01-16-2013 09:10 AM
Have an ETA on when these will be shipping?
aparke4 01-16-2013 01:18 PM
Currie add on includes both uppers of just passenger upper?
EugeneTheTJ 01-16-2013 02:10 PM
Any clearance issues?
cheftrail 01-16-2013 04:39 PM
how much?
aparke4 01-17-2013 10:11 AM
Pre order full truss with currie option is 225 with no forum codes added... Not sure what retail will be after the ore order time is up.
RDaniel2405 01-17-2013 11:18 AM
Online I see that ARTEC makes a 8.8 swap kit w/ truss for a TJ. But Ive been waiting for a company to make a Truss/Swap kit for front and rear JK 44's to a TJ... Maybe someone already makes one, I dont know. Im going to search online after I post this. :)
aparke4 01-20-2013 07:43 AM
I think the 8.8 and 44 chunk are pretty similar in size as well as the tubes- maybe with some love the 8.8 kit would fit? Might be worth asking... The Jk is wider though wms to wms.
RDaniel2405 01-20-2013 09:26 AM
For some one like me with dana 30/35 there would be a lot of advantages. I have read online that some people have done front and rear jk axles for less than $2000
- The axle tubes are longer, wider, and thicker then the TJ axle tubes, axle truss will make it stronger. A Unlimited JK weighs over 1000lbs more than a standard TJ
- Much stronger ring and pinion
- Steering components and knuckles are beefier
- The JK Rubicon axles are 32 spline, the JK non-rubi axles are 30 spline vs the 30 spline TJ Rubi axles.. or even the 27 spline D35 and D30 TJ axles
- The front JK axles are high pinion vs the standard LP TJ axles.
- Larger brake components (rotors, calipers, pads) available at any parts store. Disc brake upgrade with OEM parts if going form TJ35 to JK44
ARTEC 02-13-2013 10:17 AM
If you are thinking about getting some of ours parts, NOW would be a great time to do it. 15% off all ARTEC made products but HURRY, its over after Friday.
http://sphotos-b.xx.fbcdn.net/hphoto...63959248_n.jpg
Joe Dillard 02-13-2013 10:29 AM
Hi Nate :wave:
A friend of mine just received one of these trusses that we will be installing in his XJ soon. He came by yesterday to show it to me. Nice stuff! :highfive:
slmason72 02-13-2013 03:35 PM
Call for availability? I already have the Currie joints for the axle ends of the UCA. Any reason not to cut the passenger side to length and weld it to the top of the truss? Keyholes could be used for bottom/reinforcement welds... Might have to disassemble the JJ to weld it...
Joe Dillard 02-13-2013 09:11 PM
That's our plan on my friends.
The time now is 06:25 AM.
