Custom Parts - NalinMFG - Page 9 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Custom Parts - NalinMFG
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 11-28-2013, 02:44 AM   #121
AMA-JEEP
Rock rings for my DC1 wheels
Hi there, i have 4 DC1 wheels from Dick Cepek i was wondering of you could make 4 rock rings that would fit on my wheels? They are 16"
http://www.explorerforum.com/forums/...d.php?t=252447 i wonder if u could find the measurements between the bolts or if i need to get them from my wheels? And how would i measure the distance between the bolts? Let me know thanks
/l ,[____],
l--l--()lllllll()-
()_)-()_)--o-)_)
AMA-JEEP is offline   Reply With Quote Quick reply to this message
Unread 11-28-2013, 03:02 PM   #122
NalinMFG
Are those 12 holes threaded? I have no way of obtaining the dimensions outside of you measuring or sending me one. I'd be glad to explain how to measure it if you're interested in doing it.
[URL="http://www.NalinMFG.com/"][SIGPIC][/SIGPIC][/URL]
[URL="http://www.jeepforum.com/forum/f43/tj-5-25-speaker-adapters-nalinmfg-1325275/"]5.25" TJ Speaker Adapters[/URL]
[COLOR="DarkOrange"]
Linkedin:[/COLOR] [URL="http://www.linkedin.com/pub/andrew-nalin/30/65/825/"][B]Andrew Nalin[/B][/URL]
[COLOR="DarkOrange"] Email:[/COLOR] [B][email]NalinMFG@gmail.com[/email][/B]
[COLOR="DarkOrange"]Website: [/COLOR][B][URL="www.NalinMFG.com"]www.NalinMFG.com[/URL][/B]
[COLOR="DarkOrange"]Facebook: [/COLOR][B][URL="www.Facebook.com/NalinMFG"]NalinMFG[/URL][/B]
NalinMFG is offline   Reply With Quote Quick reply to this message
Unread 11-28-2013, 10:12 PM   #123
AMA-JEEP
Yes sir, i'm interested how do i measure the bolt spaces? And yes they are pre threaded bolts already in the wheel, let me know if i need a special tool. Thanks
/l ,[____],
l--l--()lllllll()-
()_)-()_)--o-)_)
Unread 11-29-2013, 09:24 AM   #124
NalinMFG
OK, I'll try to explain this on here for the benefit of everyone. You'll only need a tape measure, but I recommend either starting 1" in or with another number so that you eliminate the play in the end mechanism.
You need two fixed/known points to start with so I would pick a pair of those holes and find how far apart they are on center...for the sake of this thread I will call it 3". You will measure the straight line distance from every hole (on center) to both fixed points. I will then do what we call "throwing circles" -- the straight line distances you provide will be used as the radii of a circle. Because there are two measurements to every point the circles will intersect. The intersection is the center point of the bolt hole we are looking for.
Unread 12-03-2013, 04:33 PM   #125
NalinMFG
I can do more than just Jeeps:
Unread 12-04-2013, 08:50 AM   #126
NalinMFG
Does your project need a custom part?
Unread 12-04-2013, 09:43 PM   #127
AMA-JEEP
Don't think i forgot about measuring, i just been busy but i understand the way of measuring u suggested let me try to do it tomorrow morning.
Thanks again.
/l ,[____],
l--l--()lllllll()-
()_)-()_)--o-)_)
Unread 12-04-2013, 09:49 PM   #128
NalinMFG
Thanks again.
Get me some numbers and I'd be happy to post up a dimensionalized CAD drawing for you to double check that we're on the same page.
Unread 12-04-2013, 10:04 PM   #129
AMA-JEEP
You bet
Sent from AutoGuide.com Free App
/l ,[____],
l--l--()lllllll()-
()_)-()_)--o-)_)
Unread 12-10-2013, 04:59 PM   #130
AMA-JEEP
Wheel pic
/l ,[____],
l--l--()lllllll()-
()_)-()_)--o-)_)
Unread 12-10-2013, 05:22 PM   #131
AMA-JEEP
Here are the measurements, I hope this makes sense, I tried to get them as close as I could, with the tire being on the rim couldn't really get a perfect measurement, but here it goes to the nearest 1/16 of an inch.
From the 1 point
1-12= 2-3/16 of an inch
1-2= 6-5/16
1-3= 8-5/16
1-4= 13 3/16
1-5= 14 3/8
1-6= 16 3/8
1-7= 16-5/8
1-8= 15 3/8
1-9= 14 3/8
1-10= 1- 1/8
1-11= 8 5/16
From the 12 point
12-1= 2 3/16 of an inch
12-2= 8 5/16
12-3= 10 3/8
12-4= 14 5/16
12-5 = 15 3/8
12-6 = 16 5/8
12-7= 16 7/16
12-8= 14 3/8
12-9= 13 3/16
12-10= 8 5/16
12-11= 6 5/16
Outside measurement of the wheel it is 17-1/4" outside to outside
I might have missed an 1/8 of an inch here and there but let me know what the CAD determines, I figured it would match all the measurements going backwards but if I missed let me know
Thanks
/l ,[____],
l--l--()lllllll()-
()_)-()_)--o-)_)
Unread 12-10-2013, 05:51 PM   #132
dirtycruiser
dirtycruiser's Avatar
What's the 3 to 9, 2 to 8, 6 to 12,5 to 11, 4to 12 etc... center to center, that's one of the important numbers. Ps, they all should be exactly the same.
What is the bolt hole size that you need? Make it a hare bigger than the bolt for easy fitting.
dirtycruiser is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 05:57 PM   #133
dirtycruiser
[IMG][/URL][/IMG]
http://i125.photobucket.com/albums/p...4A66FEEA73.jpg
He made my rock rings perfectly!! Everyone loves them.
Unread 12-10-2013, 06:05 PM   #134
jeepjunkytj
I used to make and sell these. The reason I quit was because the rims WILL NOT hold up to the abuse! I had to constantly remove and replace the rings. They had to come off each time I had a flat fixed, replaced tires and to sand the rust off the ring and repaint them. After almost 2 years the bolt holes on the rims started to strip out. Also the spacer eroded the finish off the rims.
If you decide to use them, Id look at using aluminum, also the bolts are different sizes, I ran bolts through the ring and into the spacer, and in between the forks of the rims to create a more uniform bolt pattern. The ones between the forks I had to special order from fasten-all. You can see the ones I built on my web site www.in2jeepn.com
jeepjunkytj is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 07:46 PM   #135
NalinMFG
