Custom Parts - NalinMFG - Page 6 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Custom Parts - NalinMFG
IRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TeraFlex Now at Rockridge 4WD! BEST DEALS around!
Unread 12-12-2012, 03:52 PM   #76
NalinMFG
Originally Posted by TroubleNEO View Post
If you are interested in making them I will send you my 03-06 pods for prototyping. Jeep is winding down and not really going anywhere thanks to Winter anyways. I'll leave the speakers mounted in them as is now, the same way most people do it, and you'll be able to see the issue with mounting them that causes the vibration immediately.
edit: Actually, I just remembered you sold Polk DB's. Go open one of the boxes and find the round black plastic adapter/spacer ring. That is screwed into the speaker pod first, and then the speaker to it.
PM on the way.
[URL="http://www.NalinMFG.com/"][SIGPIC][/SIGPIC][/URL]
[URL="http://www.jeepforum.com/forum/f43/tj-5-25-speaker-adapters-nalinmfg-1325275/"]5.25" TJ Speaker Adapters[/URL]
[COLOR="DarkOrange"]
Linkedin:[/COLOR] [URL="http://www.linkedin.com/pub/andrew-nalin/30/65/825/"][B]Andrew Nalin[/B][/URL]
[COLOR="DarkOrange"] Email:[/COLOR] [B][email]NalinMFG@gmail.com[/email][/B]
[COLOR="DarkOrange"]Website: [/COLOR][B][URL="www.NalinMFG.com"]www.NalinMFG.com[/URL][/B]
[COLOR="DarkOrange"]Facebook: [/COLOR][B][URL="www.Facebook.com/NalinMFG"]NalinMFG[/URL][/B]
NalinMFG is offline   Reply With Quote Quick reply to this message
Unread 12-17-2012, 04:58 PM   #77
NalinMFG
Unread 12-19-2012, 02:32 PM   #78
nmtj
Any possibility that you can fab a Warn 8274 winch plate? I can provide more of what I'm wanting once I get the winch. Thanks!
nmtj is offline   Reply With Quote Quick reply to this message
Unread 12-19-2012, 03:19 PM   #79
NalinMFG
PM on the way
Unread 12-30-2012, 12:14 PM   #80
NalinMFG
What does your Jeep need?
Unread 01-11-2013, 11:20 AM   #81
NalinMFG
What projects are you working on?
Unread 01-21-2013, 09:40 PM   #82
NalinMFG
TJ Vent Cover
Unread 01-27-2013, 01:16 PM   #83
Unii
Pm sent
Unii is offline   Reply With Quote Quick reply to this message
Unread 01-28-2013, 04:15 PM   #84
NalinMFG
Originally Posted by Unii View Post
Pm sent
Unread 01-28-2013, 05:05 PM   #85
Unii
youre the man.
Unread 01-28-2013, 08:15 PM   #86
PA_YJ19
Hey man I may b interested in a set if beadlock rings as well. For a 15 inch rim, the guy I bought mine off of riveted every other hole so I only have screws in half the holes. I'd like to make a set of rings to cover over the holes I don't use and also look better than the generic ones I have now. The look exactly the same as a Mickey Thompson simulated beadlock.
There's a pic of what I have now...Let me no what u think or if u can help. I was thinkin mayb little skulls cut into the beadlock rings but open to nething.
PA_YJ19 is offline   Reply With Quote Quick reply to this message
Unread 01-28-2013, 10:29 PM   #87
NalinMFG
Attachment 553147
Are you wanting to completely replace the simulated rings or put something over top the existing rings?
Here are factory replacements:
http://www.mickeythompsontires.com/w...?item=RingKits
I'd need to know what the outside diameter of the ring is, where the bolt holes are(to include any offset holes like where their logo is engraved), what your desired inside diameter is, material thickness, and if you have a specific skull shape in mind.
Unread 01-28-2013, 11:07 PM   #88
PA_YJ19
Yeah I want to replace them, but I don't want the factory replacements. I can measure the diameter for u tomorow, I like the way the ones u did for the other guy look. I was just thinking mayb a skull instead of the small squared off holes u did. I would think 1/8 or 3/16s would b thick enough. What thickness do u usually use? I can measure the holes and the diameter of the ring, what other measurements would u need? Mine r not actual Mickey Thompsons, they r a knockoff that look like them. They don't have ne logo at all they just have bolt holes every like 2 inches the hole way around. Ill measure tomorow and take a couple pics up close when I do so, that way u can figure it all out.
Unread 01-28-2013, 11:19 PM   #89
PA_YJ19
There's a better pic of whats going on, half the holes had rivets in them and I drilled them out, so ill just need half as many holes. Right now u can see the holes I don't use an it makes them look rather dumb.
Unread 01-29-2013, 06:59 AM   #90
NalinMFG
Attachment 553312
10-4. The numbers are hard to see in this pic, but it shows pretty much everything I'd need to know in order to build your rings without holding one.
Hole diameter, outside ring diameter, center line of the bolt pattern (can enlarge/elongate bolt hole diameter to compensate for possible inaccuracies), desired inner ring diameter, and desired center line(or top/bottom) of skulls.
Also need to know how many holes you'd like, if you have valve stem cutout shape/location preference(if at all), and material thickness (I think 1/8" would be more than enough for your application).
