Custom Parts - NalinMFG - Page 2 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Custom Parts - NalinMFG
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 09-19-2012, 12:59 PM   #16
jstone326
jstone326's Avatar
Damn, you do some nice work! Especially for someone working on their own and not even out of college. Do you have your own shop? I will def keep you in mind for custom work. I can def engineer what I want, but I usually don't have time to also make it.
Could you pm me a very general, non-binding quote for a custom roll cage? In pieces: I'd weld it in, but it would be nice to have someone else source the tubing and notch and cut everything. I just want a ballpark number to have in my head as a comparison to other cages out there.
Thanks
'Murica
jstone326 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2012, 06:23 PM   #17
jlemond
Do you do machine and lathe work?? If so could you make something similar to this. http://www.jeep4x4center.com/lever-b...4897626aa.html
Jeep does not make the lever for the inside/outside air door (Recirculating Air) anymore and I broke mine. It is very similar to ^^^that^^^ one, but still different enough for it to not work. It should be made of aluminum but if it were lite enough steel would work. The stock part is molded plastic, maybe ABS??? So it would need to be lite.
The difference between men and women- "If a key opens many doors, it is considered the master. If a door is opened by many keys, well that's a bad lock."
jlemond is offline   Reply With Quote Quick reply to this message
Unread 09-19-2012, 07:35 PM   #18
NalinMFG
Thanks
I have a 1200sq ft detached building behind our home- I own a lathe, mill, press, brake, JD2 bender, and welder. A friend of mine runs a laser shop - I do all the CAD work.
If you can show me a rough sketch of what you're looking at I can. I base quotes off of estimated material and time -- I don't know if you're thinking of something simple or complex.
[URL="http://www.NalinMFG.com/"][SIGPIC][/SIGPIC][/URL]
[URL="http://www.jeepforum.com/forum/f43/tj-5-25-speaker-adapters-nalinmfg-1325275/"]5.25" TJ Speaker Adapters[/URL]
[COLOR="DarkOrange"]
Linkedin:[/COLOR] [URL="http://www.linkedin.com/pub/andrew-nalin/30/65/825/"][B]Andrew Nalin[/B][/URL]
[COLOR="DarkOrange"] Email:[/COLOR] [B][email]NalinMFG@gmail.com[/email][/B]
[COLOR="DarkOrange"]Website: [/COLOR][B][URL="www.NalinMFG.com"]www.NalinMFG.com[/URL][/B]
[COLOR="DarkOrange"]Facebook: [/COLOR][B][URL="www.Facebook.com/NalinMFG"]NalinMFG[/URL][/B]
NalinMFG is offline   Reply With Quote Quick reply to this message
Unread 09-19-2012, 07:39 PM   #19
NalinMFG
Yes(but nothing overly complex though...it's manual, I have limited tooling, and I am not going to call myself an expert). I can read the lever-blend-air-door in the link, but it takes me to the main page.
Unread 09-19-2012, 08:09 PM   #20
jstone326
jstone326's Avatar
That's sick! I wish I had that. I'll try to get a sketch to you, but basically I want it similar to the AtoZ kit that adds on to the stock cage. But with some cross members on the sides in the back.
'Murica
Unread 09-19-2012, 09:08 PM   #21
bdennison
I will get a sketch with measurements what's a good email to send it to you and will you be able to ship a bumper to 41129
bdennison is offline   Reply With Quote Quick reply to this message
Unread 09-19-2012, 09:16 PM   #22
NalinMFG
PM on the way
Unread 09-19-2012, 09:41 PM   #23
NalinMFG
Evansville Fire Department
Dimpled Gusset
Unread 09-19-2012, 09:54 PM   #24
phillies4752
phillies4752's Avatar
You have some talent!! Good luck with the business!
I MAKE POOL BALL SHIFT KNOBS FOR $15
PM me if interested
Got Balls?
phillies4752 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2012, 10:39 PM   #25
NalinMFG
Thank you.
Gussets for a VW sandrail:
TJ 5.25" Speaker Adapters(if you didn't already know):
TJ Fuel Cell Ring:
Custom flat pitman arm:
Unread 09-21-2012, 01:35 PM   #26
NalinMFG
3/16" dimpled H1 stiffeners / rock rings
Unread 09-22-2012, 01:42 PM   #27
NalinMFG
62mm throttle body spacer bored to 64mm for a Jeepforum member:
Unread 09-25-2012, 04:24 AM   #28
lockedwheels
Can you send me a quote for 10 guessets. I would like the shape of my avatar cut into them.. No words just the shape. shipped to 29040. THANKS !!!
lockedwheels is offline   Reply With Quote Quick reply to this message
Unread 09-25-2012, 08:25 AM   #29
NalinMFG
PM sent
Unread 09-27-2012, 06:43 PM   #30
NalinMFG
What can I do to make your build easier?
