Custom Parts - NalinMFG - Page 11 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Custom Parts - NalinMFG
Savvy/Currie Aluminum Control ArmsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAlloy usa heavy duty ball joint kits
Unread 12-16-2013, 11:47 PM   #151
lockedwheels
Originally Posted by NalinMFG View Post
You could run bearclaw latches on the inside
Never thought about those....interesting
lockedwheels is offline   Reply With Quote Quick reply to this message
Unread 12-21-2013, 11:38 AM   #152
jeepjunkytj
I'm sorry that you had trouble with the ones that you made. What was the cause of the problems -- you just say that "the rims will not hold up to the abuse" -- what kind of abuse are you talking about? There are THOUSANDS of vehicles on the road with metal rings bolted to their wheels.
If the threads are stripping and the ring was able to move/erode the finish then you did not torque the bolts properly or used the wrong thread pitch. Loctite would also prevent the bolts from ever loosening.
Yes they'd need to come off to change a flat tire...what makes you think otherwise? Tire irons pry against the lip of the wheel unless it's done on a machine. (Really though, I guess they could stay on if the outer diameter of the ring is less than flush with the lip)
I'm having a hard time understanding what you mean by "engineering the issues out of them"?
I would use a bottoming tap to chase the threads if they're not too far gone. If they are then it'd need to be drilled out and tapped to a larger diameter.
The bolts were the correct thread count and pitch, After bolting them on and removing them each time for the tire machine to remove the tire from the rim, AND to remove the rock ring from the rim so I could sand off the rust and repaint the threads on the rims started to pull out, Lock tight and the such keeps the bolts tight, and that is what I used, but again after a 2 years I was having threads strip out on the rim. And the fear of loosing a ring at road speed and hurting someone was more liability than I wanted.
As for the Finish... I contacted the rim manufacturer and spoke with them. They stated that they were having issues with the factory bolts eroding the finish on the rims...that is why the next generation o the DC1&2 rims no longer have the bolts on them. Now when you bolt a spacer on the rim the erosion is accelerated. If you have any questions feel free to PM me your number and Ill explain it better...if I can
jeepjunkytj is offline   Reply With Quote Quick reply to this message
Unread 12-22-2013, 02:00 PM   #153
NalinMFG
So you're saying that the tapped wheel threads gradually stripped themselves over two years, or you did not torque them correctly and the aluminum (low tensile material) lost the fight with steel (higher tensile material) over the course of removing/installing several times?
As for your finish...metal on metal is going to erode any finish. Rubber washers or some type of gasket may have assisted in alleviating those issues. It'd hard to say with finishes, especially when you claim that the manufacturer admits to having some type of preexisting issue.
I'm having a hard time following where you're going with this? Something you made, installed, and used didn't work so no one should use outer wheel rings? Every bolt on a moving object needs to be torqued correctly and done so in a star pattern. I can almost guarantee that the bolt issues you had could have been fixed with a torque wrench. Take a look at some of the users in the very thread using rings on threaded aluminum wheels.
Are you looking to have a custom item made?
[URL="http://www.NalinMFG.com/"][SIGPIC][/SIGPIC][/URL]
[URL="http://www.jeepforum.com/forum/f43/tj-5-25-speaker-adapters-nalinmfg-1325275/"]5.25" TJ Speaker Adapters[/URL]
[COLOR="DarkOrange"]
Linkedin:[/COLOR] [URL="http://www.linkedin.com/pub/andrew-nalin/30/65/825/"][B]Andrew Nalin[/B][/URL]
[COLOR="DarkOrange"] Email:[/COLOR] [B][email]NalinMFG@gmail.com[/email][/B]
[COLOR="DarkOrange"]Website: [/COLOR][B][URL="www.NalinMFG.com"]www.NalinMFG.com[/URL][/B]
[COLOR="DarkOrange"]Facebook: [/COLOR][B][URL="www.Facebook.com/NalinMFG"]NalinMFG[/URL][/B]
NalinMFG is offline   Reply With Quote Quick reply to this message
Unread 12-22-2013, 02:18 PM   #154
dirtycruiser
dirtycruiser's Avatar
I keep an allen wrench in my jeep and every couple of weeks I recheck all of my rock ring bolts. It's called typical maintenance along with greasing all joints and checking all undercarriage fasteners. When your playing like we do ya gotta expect things to come loose.
http://s125.photobucket.com/user/cre...a42bd.jpg.html
dirtycruiser is offline   Reply With Quote Quick reply to this message
Unread 12-22-2013, 02:47 PM   #155
olysteve
Nice looking rig!
olysteve is offline   Reply With Quote Quick reply to this message
Unread 12-22-2013, 03:16 PM   #156
NalinMFG
Looks like yours have seen some use!
Unread 12-23-2013, 08:26 PM   #157
dirtycruiser
Hell yes! I abuse them weekly. But they love it!!! Lots of battle scars.
Unread 12-24-2013, 04:57 AM   #158
mike_breaker_5
mike_breaker_5's Avatar
posting for future updates. just found your vendor thread and website. i'm loving what you have available!
Ratmonkey donation page. all proceeds will go to his family.
http://www.youcaring.com/memorial-fu..._source=widget
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
http://www.jeepforum.com/forum/f22/m...r-junk-990191/
mike_breaker_5 is offline   Reply With Quote Quick reply to this message
Unread 12-25-2013, 07:57 PM   #159
jeepjunkytj
Ok. I know that the bolts were torqued. I hope that you can make them...they look good on that rim. All I was trying to say was I tried it and there was an issue ...I hope that you can enginer my proplems out of it.
Unread 12-26-2013, 11:11 AM   #160
NalinMFG
I appreciate your concern for people wanting to use bolt on rock rings, but now I am telling you as a machinist that threads do not strip themselves. Wear and tear always has a reason. There are no problems to "engineer" out of a piece of metal that bolts to threaded holes. I don't know how else to politely say that.
I remind readers that jeepjunkytj is referring to rings that he made/installed himself and the faults mentioned are no way related to a NalinMFG product.
Unread 12-26-2013, 04:03 PM   #161
olysteve
That is what it seems to me that he was trying to do.
Nalin mfg makes quality products, not something hacked together.
Unread 12-27-2013, 01:11 AM   #162
gougeanator
Do you do any like license plate trampstamps like poison spyder does but for 97-06
gougeanator is offline   Reply With Quote Quick reply to this message
Unread 12-27-2013, 12:55 PM   #163
NalinMFG
I have done several vent covers. The 03-06 are bent like a top hat to clear the vent if you are looking to add a license palte, but I don't have any pictures handy. 97-02 can be flat.
Unread 12-27-2013, 01:00 PM   #164
NalinMFG
I do more than flat stuff:
1.75" DOM, 1.75" HREW, and 1" DOM on the shelf.
Unread 12-29-2013, 10:02 AM   #165
NalinMFG
