At CCOR we've been working on Jeeps and axles for over 12 years here in Athens, GA. We are your one stop shop for all your axle needs!
We don't just sell parts we also install and fabricate what you need!
Here is a small list of some of the axle related work we do here at CCOR!
Gear, locker, axles, ball joints, bearings, and hub installs!
Axle swaps! 8.8 rears with disc brakes, for your TJ's, XJ's, YJ's, etc
We use Artec Industries for most of these but we can custom build also!
Dana 44, Dana 60, GM 14 bolt, swaps front or rear.
Yes even 14 bolt custom front axles!
We can cut and turn your front inner C's for the correct steering geometry and pinion angles in the front.
HD after market Inner C's and knuckle install's using Solid Axle or Crane
High Steer Conversions!
Truss installs or custom fabricated!
We can build a complete crate front or rear end for just about any Jeep.
We use Ruff Stuff and Trail Gear if you want a custom fabricated 9" or 14 bolt drop out third!
We also offer Solid Axle and Currie Axle assemblies too! Dana 60 or Dana 70's!
At CCOR we've been working on Jeeps and axles for over 17 years here in Athens, GA. We are your one stop shop for all your axle needs!
Now is the time for regears!!
With great prices on installations and Yukon's summer time rebates, the deals can't be beat!!
PM, post or give us a call....
706-559-9609
Whether it's an axle swap or beefing up your existing axle,
CCOR has the Artec products you need at great prices!!
706-559-9609
CCOR has the products and know how you need to make it happen!!
706-559-9609
Always great deals on gears, lockers and install kits!!
Give us a shout or shoot us a PM and let us save you some money on your next project...
706-559-9609
706-559-9609
706-559-9609
Are you looking for a great selection of trusses, tabs and other builders parts?
If you are stop where you are at and let ARTEC and CCOR get you equipped.
We carry the entire selection of parts from Artec.
So pm, post or give us a shout @ 706-559-9609 today for a quote.
Are Grand Wagoneer differential carriers and their associated parts interchangeable with J10 axles? I know the axles aren't , the carrier and it's parts are what I'm wondering about. Thank you very much.
706-559-9609
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
