Currie Currectlync Steering Upgrade Kits and Currie Anti-Rock Sway Bar Kits - JeepForum.com
post #1 of 40 Old 04-13-2013, 08:35 AM Thread Starter
Baseline 4x4
Baseline 4x4's Avatar
1979 CJ5
Currie Enterprises Antirock® Sway Bar Kit
The Currie Antirock® Sway Bar Kit provides balanced performance of front and rear suspension for rugged off-road conditions as well as a light weight, trick looking aluminum arms. It gives the driver increased traction by balancing and distributing the weight and traction over all four tires. The Antirock® Off Road Sway Bar is designed to directly replace the stock Jeep sway bar and is an easy bolt on installation. The sway bar is made of SAE 4130 Heat-treated steel for ultimate strength. This is the same quality used in professional off-road competition sway bars. The Currie Antirock® Sway Bar does not need to be disconnected for off-road use. CAUTION: Jeeps will have more body roll than stock. This sway bar may be used on the street however, it will not provide the same performance as the stock setup.
Contact us and we can help you decide which is the best Antirock Kit for your Jeep!
Currie Enterprises Currectlync Heavy Duty Steering System
This is the 1 1/4" forged alloy steel drag link only out of the Currie Currectlync® heavy duty tie rod kit. This unit features an oversized 1 1/8" threaded adjuster, giant clamps, and threaded ball joint end at the pitman arm end, and it provides up to 200% more strength than the original equipment drag link. This unit will only work as a replacement part for the Currie system - it may not be used as in conjunction with any stock tie rod parts. This unit is rated at 200% stronger than than the stock part.
Baseline 4x4 Outfitters
Baseline 4x4 is offline
post #2 of 40 Old 04-27-2013, 10:19 AM Thread Starter
Baseline 4x4
1979 CJ5
Baseline 4x4 Outfitters has Currie Enterprise products at great prices. Contact us for a quote today!
post #3 of 40 Old 05-06-2013, 08:25 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Currie Systems at www.baseline4x4.com or contact us for a great quote.
post #4 of 40 Old 05-14-2013, 08:43 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Currie parts and accessories at www.baseline4x4.com Great prices and free shipping on orders over $199.00
post #5 of 40 Old 05-14-2013, 08:51 AM
wlo2000
I need an SYE complete kit. (Not sure what an SYE conversion entails). How much would that be from you guys to 21037? Thanks!
wlo2000 is offline
post #6 of 40 Old 05-14-2013, 09:27 AM Thread Starter
Baseline 4x4
1979 CJ5
The Slip Yoke Eliminator Kit that we offer includes everything needed to convert your NP231J transfer case over for use with a CV style drive shaft. If you need the drive shaft, we sell these for $289.95.
Let me know if you need any additional information.
Thanks,
Tony
post #7 of 40 Old 05-24-2013, 04:54 PM Thread Starter
Baseline 4x4
1979 CJ5
Get your Currie Products at www.baseline4x4.com
post #8 of 40 Old 06-11-2013, 03:38 PM Thread Starter
Baseline 4x4
1979 CJ5
Get your Currie parts at www.baseline4x4.com
post #9 of 40 Old 07-09-2013, 10:22 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Currie Parts at www.baseline4x4.com
post #10 of 40 Old 08-01-2013, 02:43 PM Thread Starter
Baseline 4x4
1979 CJ5
post #11 of 40 Old 08-13-2013, 12:00 PM Thread Starter
Baseline 4x4
1979 CJ5
post #12 of 40 Old 08-17-2013, 12:29 AM Thread Starter
Baseline 4x4
1979 CJ5
Contact us for a quote on Currie Products today!
post #13 of 40 Old 08-22-2013, 08:14 AM Thread Starter
Baseline 4x4
1979 CJ5
Free shipping on all Currie orders over $50.00 at Baseline 4x4 Outfitters
post #14 of 40 Old 08-27-2013, 04:02 PM Thread Starter
Baseline 4x4
1979 CJ5
Free shipping on Currie Antirocks at www.baseline4x4.com
post #15 of 40 Old 09-03-2013, 07:42 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Currie Jeep Parts at www.baseline4x4.com today!
You may not post new threads
