The Cure for your Tie Rod Roll! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > The Cure for your Tie Rod Roll!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFord Explorer 8.8 4340 Chromoly Axle Shaft Kit C Clip Elim07-15 jeep JK Spare Tire Carrier Delete Plate
Unread 02-15-2015, 07:36 PM   #1
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
Finally!
For as long as there have been Jeeps they have wandered down the road. Wandering along...
If you have driven a Jeep, you know the feeling. The steering wheel goes two inches to the right, two inches to the left and then back again, while your vehicle stays in a relatively straight line. That is the result of your Tie Rod rolling forward and backward forward and backward again and again. That's simply because there is nothing there to prevent it from doing that. And early wear on tie rods simply because they are always in motion and torn boots because they have been flexed about a jillion times.
The Cure!
This small piece of machined Delrin plastic has had a lot of thought put into it. So much that we decided it would be the First Ruffstuff product we patented! Used against only the face of our Y-Link Adapter or a common Y-Link Tie Rod. It gives a self lubricated,fixed yet slightly flexible surface for the Tie Rods to run against. The drag link does not flop forward or backward whatsoever yet in common usage it is allowed to roll which causes the steering wheel dead spot and allows for the tie rod roll.
Not all TRE's are created equal. Some have a long pin, some have a short pin. This product has been specifically made to work with a GM 1 Ton TRE. In some cases you may have to sand the outside surface to allow for a flush fit. You do not want a tight fit, you want a snug fit. It naturally has a grease pocket built in, this is meant to ride beyond the taper in place of the standard dust boot. These are made for 1 Ton TRE's and also work for 7/8" Heim Joints.
This product also goes great with our Offset Tie Rods if you also use our second pattented item, our Y-Link Adapter that you can find here Y link adapter 18TPI (TRE threading) - RuffStuff Specialties When using these 2 together you still retain the fine adjustability of a standard Tie Rod!
The Cure! - RuffStuff Specialties
Dan Fredrickson
www.ruffstuffspecialties.com
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline   Reply With Quote Quick reply to this message
Unread 02-25-2015, 01:53 PM   #2
Dan Fredrickson
Vendor
These are selling quick!
Dan Fredrickson
Unread 03-04-2015, 12:39 PM   #3
Dan Fredrickson
Vendor
Wow! Its amazing how popular these have became!
Dan Fredrickson
Unread 04-09-2015, 12:39 PM   #4
Dan Fredrickson
Vendor
These are easily becoming a favorite!
Dan Fredrickson
Unread 04-26-2015, 09:18 AM   #5
Dan Fredrickson
Vendor
Now available for stock steering on Jeeps! Call your order in, they just arrived and aren't yet on the website
Dan Fredrickson
Unread 04-27-2015, 12:52 AM   #6
26679cj5
26679cj5's Avatar
Hey Dan, the weld washers I ordered from the other day worked great for repairing the trackbar mount on my TJ!
26679cj5 is offline   Reply With Quote Quick reply to this message
Unread 04-27-2015, 01:34 PM   #7
Dan Fredrickson
Vendor
Awesome! Glad you like them! Let us know if there is anything else we can help with!
Dan Fredrickson
Unread 05-26-2015, 08:33 AM   #8
Dan Fredrickson
Vendor
Worth every penny!
Dan Fredrickson
Unread 05-30-2015, 02:51 PM   #9
Dan Fredrickson
Vendor
We are shipping 25-30 of these a day, they work that well!
Dan Fredrickson
Unread 05-30-2015, 06:21 PM   #10
ski boy
Hi, Don't seem to see these on your web site? For standard Jeep steering.
ski boy is offline   Reply With Quote Quick reply to this message
Unread 06-01-2015, 11:18 AM   #11
Dan Fredrickson
Vendor
Give us a call and let our sales rep know what type of steering you have, we'll get you taken care of!
Dan Fredrickson
Unread 06-06-2015, 04:47 PM   #12
Dan Fredrickson
Vendor
Time to finally get it right
Dan Fredrickson
Unread 06-08-2015, 02:52 AM   #13
Pine_Cat
Looks great !
Pine_Cat is offline   Reply With Quote Quick reply to this message
Unread 06-08-2015, 08:31 AM   #14
Dan Fredrickson
Vendor
Thanks! We worked hard to make them happen!
Dan Fredrickson
Unread 06-25-2015, 04:57 AM   #15
Pine_Cat
Would this product work with stock TJ steering, with the draglink that runs to the steering knuckle? Would I be able to attach this where the stock tie rod attaches to the draglink?
Is the stock TRE too small? Would this product fit better with a ZJ tie rod? They're not really 1-ton TREs, either, but I'd like to try the Cure if it can fit a stockish set-up.
