CrawlWorx new lower link mounts! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > CrawlWorx new lower link mounts!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 03-01-2012, 11:09 AM   #1
CrawlWorx
Lower link mounts for your 3 or 4 link builds. These mounts have a skid plate on the bottom to protect the joint from rocks and a drainage hole. The side plates allow for full range of moment from the joint. There are alignment tabs for quick and easy assembly and welding. Fits 3" axle tubes, can be easily modified to fit different tube sizes. These ship un-welded.
Mounting Width: 2.625"
Hole Size: 9/16"
Thickness: .250"
Material: Raw Steel
*Sold in pairs
Opitions-
Offset: 0*, 10*, 22.5*
29.99
http://crawlworx.3dcartstores.com/L...unts_p_71.html
[B][SIZE="4"][URL="http://www.CrawlWorx.com"]CrawlWorx.com[/URL][/SIZE][/B]
Custom Offroad Parts
Montrose, CO - 970.626.6090
[B][COLOR="yellow"]JeepForum Discount Code: [I][B]jeep10[/B][/I][/COLOR][/B]
CrawlWorx is offline   Reply With Quote Quick reply to this message
