Complete Axle Options Expanded !!!! ECGS - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Complete Axle Options Expanded !!!! ECGS
Rough Country Jeep Suspension Deals at Rockridge 4WD!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 09-22-2014, 11:50 AM   #1
ECGS
Vendor
ECGS's Avatar
We now Offer 4 Rear axle Options For most Jeeps, If you can't find your Jeep call us we can likely build it. http://eastcoastgearsupply.com/c-916...ssemblies.html
From Street to Rock Bouncing - An option for nearly any Budget
Reconditioned Ford 8.8 - 8.8 Ring Gear, Standard Disc brake upgrade, any Carrier Choice, Optional C-clip Elim Upgrade, Truss options.
New Standard Dana 44- 8.5 inch Ring Gear, Bolt in 30 Spline Chromo Axles, Any Carrier Choice from Open Diff to ARB. Optional Disc brake upgrade or reuse Stock brakes.
New Dana 44 Extreme - 8.9 Inch Ring Gear, Bolt in 35 Spline Chromo Axles, Carrier Choice ARB or OX. Optional Disc brake upgrade or reuse Stock brakes.
New Dana 60 - 9.75 Inch ring Gear, Bolt in 35 Spline Chromo Axles, Any Carrier Choice from Open Diff to ARB. Optional Disc brake upgrade or reuse Stock brakes.
Differential Sales & Service
Quality Gears, Lockers, Axle Shafts, and other drivetrain products at a fair Price
http://www.eastcoastgearsupply.com
919-672-2705
ECGS is offline   Reply With Quote Quick reply to this message
Unread 10-09-2014, 01:39 PM   #2
ECGS
Vendor
ECGS's Avatar
Different options to fit different budgets and different applications
919-672-2705
Unread 11-21-2014, 02:13 PM   #3
ECGS
Vendor
ECGS's Avatar
New options ready to be built custom to your specs.
919-672-2705
Unread 12-31-2014, 04:00 PM   #4
ECGS
Vendor
ECGS's Avatar
Check out the options and don't settle you can have an axle built the way you want.
919-672-2705
Unread 01-20-2015, 10:01 PM   #5
ECGS
Vendor
ECGS's Avatar
Parts in stock and ready to be built to your specs
919-672-2705
