Clayton Off Road XJ Skid Plate - JeepForum.com
post #1 of 1 Old 03-29-2014, 01:16 PM Thread Starter
Clayton Offroad
Clayton Offroad's Avatar
Our Jeep Cherokee XJ 1/4 flat skid plate was designed as an addition to our Clayton Off Road Mfg. rear coil conversion lift kits. This skid plate is CNC laser cut, and CNC bent for superior accuracy, fit, and strength.
It bolts onto the front 3 piece cross member, and requires a custom rear mount to be welded into the unibody frame rails.
This rear mount is part of the coil conversion kit and necessary to install this skid plate.
Kits comes with 1/4 flat skid, and hardware ONLY. This kit is NOT intended to be used on a stock setup.
For more information, or to place an order, check them out here.
Alex
Marketing Director
Clayton Off Road
Follow us on
Clayton Offroad is offline
You may not post new threads
