Clayton Off Road WJ Long Arm Kits! - JeepForum.com
post #1 of 6 Old 05-10-2014, 01:01 PM Thread Starter
Clayton Offroad
Clayton Offroad's Avatar
Clayton Off Roads package deal lift kits are specifically designed to offer the best all around performance. This kit is put together using only the highest quality parts, and vigorously tested to meet our stringent requirements. Because this is a package deal lift kit, you know that everything is going to properly work together, to give you the best performance possible. Making bulletproof arms is our name to fame and we back that with our lifetime warranty. But thatís only one step of the equation. When this package deal was put together we had one main goal in mind. We wanted to build the strongest, most reliable long arm kit on the market. Price is important, but quality has to be a priority. Ease of installation is also very important, but strength and reliability has to be above the rest. If you save a few hundred dollars, and it falls apart in 6 months, thatís not saving money. If you can install it for less or faster, but it fails or leave you stranded in the woods, thatís not saving time or money either. These are all items we thought about when designing, installing and testing our lift kits. Our obsession to details, is what brings you the best riding, strongest most reliable lift kits on the market, period.
This specific 4.5 inch Grand Cherokee WJ lift kit was designed to run 30-31 inches tires. Kit includes, a front 3 piece cross member, unibody rails, rear frame brackets, rear 4 link plate, all 8 adjustable control arms with hardware, front and rear coil springs, front adjustable trackbar, front sway bar disconnects, and 8 D shaped spacer plates. Shocks are optional and we recommend the Bilstein 5100s.
Key Features
Weld On Design For Maximum Strength
Unibody Strengthening Subframe Design
8 Fully Adjustable Control Arms
JKS Adjustable Trackbar
Triangulated 4-Link Axle Bracket
Lifetime Warranty!!!
Alex
Marketing Director
Clayton Off Road
Follow us on
Clayton Offroad is offline
post #2 of 6 Old 07-18-2014, 01:45 PM Thread Starter
Clayton Offroad
We lifted this WJ in the spring, it recently got some new bumpers:
Alex
Marketing Director
Clayton Off Road
Follow us on
post #3 of 6 Old 09-16-2014, 08:15 PM Thread Starter
Clayton Offroad
Bumping this back up, this supercharged WJ has been using our 6" Long Arm System:
If you aren't quite ready for a full long arm system, we offer short arm kits as well. Find them all online.
Alex
Marketing Director
Clayton Off Road
Follow us on
post #4 of 6 Old 09-17-2014, 06:37 AM
2000_JeepWJ_505
Price?
505 WJ SLICK
J.E.E.P. -Just Empty Every Pocket- J.E.E.P.
2000_JeepWJ_505 is offline
post #5 of 6 Old 09-19-2014, 04:02 PM Thread Starter
Clayton Offroad
That one is $2659.05
Alex
Marketing Director
Clayton Off Road
Follow us on
post #6 of 6 Old 11-13-2014, 09:31 PM
dcorn
Can I get a price on just the bolt-on 4-link bracket that goes on top of the rear D44HD? I want to make my own upper links to replace the stock A-arm using the stock body side bracket. Think the angles would be OK using your axle side bracket?
2014 Jeep Grand Cherokee Summit
dcorn is offline
You may not post new threads
