Clayton Off Road JK Short Arm Suspension Kits - JeepForum.com
post #1 of 1 Old 09-22-2014, 05:03 PM Thread Starter
Clayton Offroad
Clayton Offroad's Avatar
Entry Level JK Short Arm Kits
Clayton Off Road JK suspension lift systems are designed to give a smooth ride both on and off road while maintaining excellent handling characteristics. Our 3.5 entry level 2 door system is designed to let you run a 35 tire. Our 4.5 complete system is designed to let you run a 37 tire. These are complete bolt on systems and can be installed using basic shop tools. All arms feature either Currie Johnny Joints or Clevite mechanically bonded rubber bushings, which carry a lifetime, no questions asked warranty against bending or breaking.
NOTE: 2012+ require an exhaust spacer kit, and CV style driveshaft!
Clayton Off Road JK suspension lift systems are designed to give a smooth ride both on and off road while maintaining excellent handling characteristics. Our 3.5 complete system is designed to let you run a 35 tire. Our 4.5 complete system is designed to let you run a 37 tire. These are complete bolt on systems and can be installed using basic shop tools. Our systems include eight adjustable control arms, which carry a lifetime, no questions asked warranty against bending or breaking. The lower front and rear upper arms are dog legged for tire clearance. All arms feature either Currie Johnny Joints or Clevite mechanically bonded rubber bushings. An adjustable front track bar and rear track bar relocation bracket are used with our systems. An optional adjustable rear track bar is available for use with the rear track bar relocation bracket for fine-tuning the rear track or to allow pinion angle adjustments when using a CV style drive shaft. Rear extended sway bar links, front and rear bump stops, front and rear extended brake lines, and 3.5 coils springs are supplied to complete our lift suspension systems.
Alex
Marketing Director
Clayton Off Road
Follow us on
Clayton Offroad is offline
You may not post new threads
