Clayton Off Road JK Short Arm Suspension Kits - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Clayton Off Road JK Short Arm Suspension Kits
JK specific skid plates from Clayton Off Road Mfg.RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comStainless Steel Door Hinge Pins
Unread 03-08-2014, 03:23 PM   #1
Clayton Offroad
Vendor
JeepForum 2012 Vendor Giveaway Participate
Clayton Offroad's Avatar
Clayton Off Road JK suspension lift systems are designed to give a smooth ride both on and off road while maintaining excellent handling characteristics. Our 3.5 complete system is designed to let you run a 35 tire, and our 4.5" system is designed to let you run a 37" tire.
These are complete bolt on systems and can be installed using basic shop tools. Our systems include eight adjustable control arms, which carry a lifetime, no questions asked warranty against bending or breaking. The lower front and rear upper arms are dog legged for tire clearance.
All of arms feature either Currie Johnny Joints or Clevite mechanically bonded rubber bushings. An adjustable front track bar and rear track bar relocation bracket are used with our systems. An optional adjustable rear track bar is available for use with the rear track bar relocation bracket for fine-tuning the rear track or to allow pinion angle adjustments when using a CV style drive shaft. Rear extended sway bar links, front and rear bump stops, front and rear extended brake lines, and either 3.5 or 4.5" (depending on which kit you select) coils springs are supplied to complete our lift suspension systems.
Alex
Marketing Director
Clayton Off Road
Clayton Offroad is offline   Reply With Quote
