Our JK production gas tank skid is almost done. Our skid is a complete replacement, instead of just a cap on the factory piece. Because of this, we will have both stock and long arm versions. The difference between the long and short arm versions are cut outs for the lower control arm mounts on the frame. Some cutting and welding will allow you to convert from one version to the other.
Our expected weight will be around 90 lbs and made from 3/16ths inch steel. If all goes according to plan, this should be on our JK in about 2 weeks for some final fitment tests before production. You will need either our Long Arm or HD Crossmember for the skid plate to work.
Alex
Marketing Director
Clayton Off Road
Alex
Marketing Director
Clayton Off Road
