Chromoly JK Wrangler Rubicon Dana 44 32 Spline Axle Shaft Kit $354.95 -
post #1 of 1 Old 12-07-2012, 09:06 AM Thread Starter
Baseline 4x4
Baseline 4x4's Avatar
1979 CJ5
We have these back in stock. Order yours before they sell out. The normal price is $374.95 but there is a $20.00 mail in rebate on these through the end of the year.
Alloy USA Rear Axle Shaft Kit, Jeep Wrangler 2007-2013 Jeep JK Wrangler Rubicon, Dana 44 Grande 32-Spline Kit Chromoly
High tensile strength 4340 Chromoly is heat-treated, tempered and induction hardened to produce these heavy-duty axles that are up to 40% stronger than stock 1040 axles. Alloy USA uses the latest splining technology, to produce splines that are stronger than traditonal cut splines. Our shafts are covered by and exclusive 10-year warrany! Rear axle shaft kits include everyting you need for your installation: both passenger and drive side shafts, seals, bearings and wheel studs.
Baseline 4x4 Outfitters
Baseline 4x4 is offline
In order to be able to post messages on the forums, you must first register.
You may not post new threads
