CCOR Job Opening! Fabricator/Mechanic - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > CCOR Job Opening! Fabricator/Mechanic
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 07-31-2013, 10:19 AM   #1
CCOR
Vendor
Classic City Off Road is looking to hire.
Job: Fabricator/ Off road shop mechanic
We need someone that is versatile and can handle a variety of tasks. Below is the list of qualifications and if you feel you meet them then and only then apply. We need someone that can perform above the rest and has previous experience in the off road industry.
Required:
Bend and notch tubing
MIG welding.
Torch, plasma cutter, saws, iron worker operation.
Must be able to perform jobs correctly within the deadline.
Our customers expect top quality work so the same will be expected out of the applicant.
Ability to assemble full turnkey buggies, Install lift kits from IFS to Long arms, to solid axle swaps.
Preferred but not required:
Tig Welding and ring and pinion setup.
Apply by sending your current resume and pictures/portfolio to classiccityoffroad@gmail.com
Pictures of previous projects with descriptions of the work performed are preferred.
www.classiccityoffroad.com
To order call 706-559-9609
Randy's Gear Supply
CCOR is offline   Reply With Quote Quick reply to this message
