CCOR in house specials! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > CCOR in house specials!
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!Yukon Ultimate 35 axle kit for c/clip axles with Yukon Zip
Unread 07-31-2014, 08:45 AM   #1
CCOR
Vendor
1979 CJ5
If you need to lift your JK or TJ or just re-gear it then now is the time!
Check out these smoking deals and call us at 855-572-GEAR to setup your appointment today!
Jeep JK 2 door or 4 door 2.5" suspension lift kit special $489 Installed! Comes with brand new Nitrogen charged shocks
Jeep TJ 2" suspension lift kit special with Nitrogen charged shocks $369 Installed!
Jeep TJ Gear installs 3.73 up to 5.13 starting at $1299 Installed and out the door. Front and rear ring and pinions, front and rear master install kits, and carriers when needed
Jeep JK Gear installs from 4.56 to 5.13 starting at $1529 installed and out the door. New ring and pinions and master install kits front and rear!
855-572-GEAR or 706-207-4140!
CCOR
1947 Commerce Road
Athens, GA 30607
www.classiccityoffroad.com
To order call 855-572-GEAR or 706-207-4140
Randy's Gear Supply
CCOR is offline   Reply With Quote
