Brand New! Quadratec LED Headlights! - JeepForum.com
post #1 of 25 Old 08-22-2014, 11:21 AM Thread Starter
Quadratec
Vendor
Quadratec's Avatar
NEW! Quadratec® LED Headlamps
See better and farther when driving at night. Replace those dim factory incandescent headlamps with an advanced Quadratec LED upgrade. Our lamp assemblies feature a solid state maintenance free design and advanced photometric technology for years of for a brighter, crisper and whiter light output that’s closer to the color temperature of actual daylight. Guaranteed to deliver dramatic improvements in light projection distance and overall visibility or your money back! Lenses have a distinct customized appearance bringing smart styling and function to a higher level. The rugged construction starts with a die-cast aluminum housing and crystal clear polycarbonate lenses for optimum protection against impacts. The solid state electronics and powerful Phillips® brand light emitting diodes (LEDs) are protected by water tight epoxy seals.
Pre-Order NOW! Available Late August!
For '55-'86 CJ & '97-'06 Wranglers $374.99 Pair
For 07-15 Wranglers $399.99 Pair
These drop-in replacements are truly plug-n-play requiring no modifications and installation takes only 20-30 minutes. Headlamps feature horizontal LED modules that divide the high and low beam reflectors. The top half of the lamp features the low beam light source that's powered by one super powerful 15 watt LED. When the high beam is activated, the bottom half becomes illuminated by four additional high powered 3 watt LEDs. These battery friendly lamps draw much less electricity than conventional incandescent lamps making them easier on your charging system. Our lamps exceed DOT and federal motor vehicle safety standards (FMVSS #108) and are approved for highway use in all 50 states. This is a true drop in replacement for all 7” round dual beam headlamp designs and come with Quadratec's 3 Year Limited Warranty.
For more information or to order your set, just click any of the images above or this link:
http://www.quadratec.com/products/product_search.php?pn=97109.000&cn=Quadratec+LED+Headlamps
We Price Match,
us for a quote
Active Hours: 9am-5pm EST Monday - Friday
Quadratec is offline
post #2 of 25 Old 08-23-2014, 11:51 AM
jeep_boy02
1980 CJ7
Looks nice and useful for sure...
Have any pics of them installed on CJs? What about an LED kit to replace all lights on a CJ or other... looking for heads, tails and turns
80 CJ7-304/T176/D300 HEI hdrs-WT D30/D44 4.56s, lockright/spool-SOA YJs W/RE AAL-35 MTRs beadlocks
jeep_boy02 is offline
post #3 of 25 Old 08-23-2014, 12:45 PM
kjmccar
Can you compare these to an OEM quality HID retrofit, please?
kjmccar is offline
post #4 of 25 Old 08-23-2014, 12:46 PM
Rougarou
Is it possible to pre-order these and still get my military discount? Crazy question
2006 TJ / (under construction)
Rougarou is offline
post #5 of 25 Old 08-26-2014, 10:57 AM Thread Starter
Quadratec
Vendor
Quadratec's Avatar
These are now in stock! If you order prior to 3:30pm Eastern today they will ship today as well!
I don't have any CJ photos at the moment, but let me e-mail my photo studio and see if they can take some and upload to the web. We have a Quadratec CJ in the shop. Thanks!
Any decent HID retrofit (HID projectors, HID kit, etc.) is going to have a better cutoff and beam pattern due to the HID projector. The same goes for JW Speaker with their projector setup. Our Quadratec LED's, Truck-Lite, KC, etc., use a reflector housing. The pattern is not as good as a projector, but still looks great.
Sure can! Just PM me with the part # you want and that you want a quote. I'll get it going for you.
Thanks!
-Rick
We Price Match,
us for a quote
post #6 of 25 Old 08-26-2014, 12:46 PM
ciphershort
2009 JK Wrangler
Definitely interested in this. Now to only make it down to that part of my mod list...
ciphershort is offline
post #7 of 25 Old 08-28-2014, 06:00 PM
kjmccar
Thanks for the honest reply. It's definitely a great option for people who don't want to get their hands dirty with a HID retrofit!
kjmccar is offline
post #8 of 25 Old 08-28-2014, 08:42 PM
whatevah
Mine were delivered yesterday! Here are my comparison shots... my stock JK housings with Silverstar bulbs and then the Qtec headlights.
for all photos the camera was set to: Canon T4i, 18-55 lens, 6400ISO, 1/30, f5.6. Photos taken on two different nights, but at a similar distance from the wall... I put the front tires on the same crack in the pavement both nights.
Stock housing with Silverstar bulbs, single light, low beam (standing in front of right light to block the beam)
Quadratec LED headlight single light on low beam. (standing in front of right light to block the beam)
Quadratec LED headlight both lights on low beam.
Quadratec LED headlight single light on high beam for pattern display (standing in front of right light to block the beam).
So... the LED lights are far brighter than stock and have a similar pattern width to the JK stock beam (a good thing!). I think I remember the Trucklites having a much narrower pattern (I had them for a couple days in 2012). There is a "hot spot" in the middle, just above the low beam. I guess that's for better highway-type light on low beam. And, the foreground isn't ignored like the stock JK ... I used to find myself using the fog lights just to illuminate the road 30 feet and closer. No longer necessary, I could barely tell that the fog lights were even turned on! High beam adds to the beam pattern, rather than switch from low to high like the factory JK. That's a huge plus!
I'm really happy I got these lights, I can't find anything to complain about. The Q logo isn't a problem for me. Really... how often do you look closely at your headlights?
Tip: use a T15 driver rather than a T15 bit on a socket... not enough clearance for a socket head.
EMT/Firefighter... 2012 Rubicon, AEV 2.5" lift, JCR stubby winch bumper with HID lights, JCR engine skid, ACE side steps.
formerly- 2001 XJ, 7" longarm, 35s, etc.
whatevah is offline
post #9 of 25 Old 08-28-2014, 09:05 PM
ciphershort
2009 JK Wrangler
Looks good!
post #10 of 25 Old 09-03-2014, 04:50 PM Thread Starter
Quadratec
Vendor
Quadratec's Avatar
No problem, guys. Thanks for posting your photos, Jerry!
We Price Match,
us for a quote
post #11 of 25 Old 09-03-2014, 06:15 PM
5jeepsIn12years
will we expect rectangular ones anytime soon??
5jeepsIn12years is offline
post #12 of 25 Old 09-03-2014, 06:24 PM
jeep_boy02
1980 CJ7
Only if they come with pink bezels for them barbie jeeps! Haha, Just pokin fun at the YJs ;-)
post #13 of 25 Old 09-05-2014, 06:21 PM
Yesfan70
Yesfan70's Avatar
I'd like to see some TJ pics if anyone has got them. I've been interested in these lights as well.
2004 Jeep WJ
Only in a Jeep
Yesfan70 is offline
post #14 of 25 Old 09-06-2014, 02:57 PM Thread Starter
Quadratec
Vendor
Quadratec's Avatar
I grabbed a quick cell phone photo for you:
-Rick
We Price Match,
us for a quote
post #15 of 25 Old 09-10-2014, 08:49 AM Thread Starter
Quadratec
Vendor
Quadratec's Avatar
Here are a few more shots I took in the parking lot yesterday:
We Price Match,
us for a quote
led head lamps , led head lights , led headlamps , led headlights , quadratec
You may not post new threads
