Bolt In Jeep JK Tie Rod Kit! - JeepForum.com
post #1 of 24 Old 06-24-2015, 08:48 PM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
For years now we have been making Steering kits that you weld yourself. Ours have been acclaimed as the highest quality and strength with 1 glaring problem to many people! You had to weld it yourself or have a shop install it for you at a high cost...
Not anymore
In April we quietly introduced a ready to go welded version of the kit many of you are using! It has the same 1.5" x .25" wall DOM tubing and our 1 ton offset TRE's with the welding requirement already done by our professional welders so you don't have to. It is truly plug and play!
This is yet another of our new plug and play parts. We have been the best at making Fabrication Parts for many years and its time we stepped out of that mold a bit
http://www.ruffstuffspecialties.com/.../JKTIEROD.html
Dan Fredrickson
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline
post #2 of 24 Old 06-28-2015, 10:38 PM Thread Starter
Dan Fredrickson
Vendor
Now we make it easy
Dan Fredrickson
post #3 of 24 Old 06-30-2015, 05:16 PM Thread Starter
Dan Fredrickson
Vendor
Give your JK the upper advantage with RUFFSTUFF!
Dan Fredrickson
post #4 of 24 Old 08-01-2015, 04:23 PM Thread Starter
Dan Fredrickson
Vendor
That's correct! Bolt in and hit the trails!
Dan Fredrickson
post #5 of 24 Old 09-17-2015, 04:10 PM Thread Starter
Dan Fredrickson
Vendor
Can't wait to hit some trails this weekend!
Dan Fredrickson
post #6 of 24 Old 11-15-2015, 07:43 PM Thread Starter
Dan Fredrickson
Vendor
All welded and ready to wheel!
Dan Fredrickson
post #7 of 24 Old 12-02-2015, 10:11 PM Thread Starter
Dan Fredrickson
Vendor
Take it by the horns this weekend
Dan Fredrickson
post #8 of 24 Old 03-11-2016, 09:48 AM Thread Starter
Dan Fredrickson
Vendor
Are you tired of seeing your tie rod smiling or frowning at you? This is the solution, and it only takes a wrench to install!
Dan Fredrickson
post #9 of 24 Old 03-25-2016, 11:21 PM Thread Starter
Dan Fredrickson
Vendor
1/4" Wall DOM, need I say more?
Dan Fredrickson
post #10 of 24 Old 04-04-2016, 11:33 AM Thread Starter
Dan Fredrickson
Vendor
You guys keep us busy cutting and welding these up.
Can't thank our awesome customers enough!
Dan Fredrickson
post #11 of 24 Old 04-11-2016, 12:23 PM Thread Starter
Dan Fredrickson
Vendor
Pre-fit and ready to drop in!
Dan Fredrickson
post #12 of 24 Old 04-25-2016, 11:35 AM Thread Starter
Dan Fredrickson
Vendor
You will know you've made the right choice when you take the stock one off, and hold it up next to ours.
Trust me, sometimes size matters.
Dan Fredrickson
post #13 of 24 Old 05-16-2016, 09:47 PM Thread Starter
Dan Fredrickson
Vendor
This is our 1 ton Offset tie rod kit, but cut and welded already so you can drop it into any JK front axle in minutes!
Dan Fredrickson
post #14 of 24 Old 05-28-2016, 05:30 PM Thread Starter
Dan Fredrickson
Vendor
Ready to drop in, and give you that little extra wiggle room!
Dan Fredrickson
post #15 of 24 Old 05-28-2016, 05:30 PM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson
You may not post new threads
