Bilstein Shock Upgrade Kits, Jeep JK TJ XJ Wranglers and Cherokees Free Shipping - JeepForum.com
post #1 of 35 Old 07-09-2013, 04:27 PM Thread Starter
Baseline 4x4
Baseline 4x4's Avatar
1979 CJ5
Bilstein 5100 Series Shock Absorber Kit
Bilstein’s 5100 Series Shocks offer traditional Bilstein technology with applications for lifted trucks, Jeeps and prerunners. 5100 Series shocks feature Bilstein's superior single tube high gas pressure design for the upmost in consistent fade-free performance and long life. Features include:Monotube gas pressure construction, Self-Adjusting Deflecting Disc Valving, High-Flow Piston Reduces Harshness, Independent Rebound & Compression Tuning, Larger Working Piston Area for Exact Damping, Superior Control for Large Diameter Tires and Designed for specific manufacturer lift kits utilizing the stock O.E.M. mounting configuration.
Bilstein 5160 Series Shock Absorber Kit with Remote Resevoir
Bilstein 5160 Series Stock Mount Remote Reservoir Shocks are direct-fit to each specific vehicle application, avoiding the fabrication generally associated with being able to run a high performance reservoir shock. The monotube shocks feature a 46mm digressive piston with self-adjusting deflective disc valving. Benefits of the reservoir include increased cooling capacity and increased shock travel.
Bilstein 4600 Series Shock Absorber Kit
Bilstein's technically superior, patented monotube gas charged design allows the excessive heat from the oil to transfer to the outer surface of the shock body and dissipate more efficiently. The dividing piston also permits the oil to expand as heat builds, preventing aeration (foaming) and viscosity loss. This allows the shock to maintain full damping characteristics as temperatures rise.The tube of a Bilstein Gas Pressure Shock Absorber is fabricated using a special extrusion method. This process achieves an extremely tight peak-to-valley tolerance and maintains consistent wall thickness. Bilstein's seamless monotube design provides superior tube strength while maximizing heat dissipation and shock life.The piston head design allows independent tuning of the compression and rebound damping forces to provide optimum ride comfort and performance without compromise. It features fewer parts than most conventional twin tube and so called road sensing shock designs. This simple, yet exceptionally functional digressive design contributes to the extreme durability and long life of Bilstein Shock Absorbers.
Baseline 4x4 Outfitters
Baseline 4x4 is offline
post #2 of 35 Old 07-15-2013, 07:00 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Bilstein Shock Upgrade Kit at www.baseline4x4.com. Free shipping and great prices.
post #3 of 35 Old 07-19-2013, 06:55 AM Thread Starter
Baseline 4x4
1979 CJ5
post #4 of 35 Old 08-02-2013, 09:06 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Bilstein shocks at www.baseline4x4.com
post #5 of 35 Old 08-10-2013, 05:59 AM Thread Starter
Baseline 4x4
1979 CJ5
Contact Baseline 4x4 Outfitters for all your off road parts and accessories at 866-554-5946.
post #6 of 35 Old 08-16-2013, 11:29 AM Thread Starter
Baseline 4x4
1979 CJ5
Upgrade your shocks with these great shocks. I am personally running the 5100's and love them.
post #7 of 35 Old 08-22-2013, 09:08 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Shock Upgrade Kit today at www.baseline4x4.com
post #8 of 35 Old 08-27-2013, 07:59 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Bilstein Shock Upgrade Kit at www.baseline4x4.com today
post #9 of 35 Old 09-03-2013, 01:26 PM Thread Starter
Baseline 4x4
1979 CJ5
Great performance Shocks for the Road, Trails, Rocks and everything else. Get yours today!
post #10 of 35 Old 09-12-2013, 10:45 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Shock Upgrade kit today!
post #11 of 35 Old 09-17-2013, 11:06 AM Thread Starter
Baseline 4x4
1979 CJ5
Free shipping on all shock kits at Baseline 4x4 Outfitters
post #12 of 35 Old 09-24-2013, 06:59 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your shock upgrade kit at www.baseline4x4.com
post #13 of 35 Old 09-30-2013, 07:34 AM Thread Starter
Baseline 4x4
1979 CJ5
Free shipping on shock upgrade kits at www.baseline4x4.com
post #14 of 35 Old 10-04-2013, 07:31 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Shock Upgrade Kits at www.baseline4x4.com today
post #15 of 35 Old 10-09-2013, 07:38 AM Thread Starter
Baseline 4x4
1979 CJ5
Free shipping and great prices on Shock Upgrade kits at www.baseline4x4.com
You may not post new threads
