BETTER BRACKETS! - ARTEC's FORM+FUNCTION Suspension brackets - JeepForum.com
post #1 of 27 Old 09-15-2011, 01:32 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
INTRODUCING ARTEC INDUSTRIES LINE OF FABRICATION BRACKETS
FORM+FUNCTION
OUR VISION - Offer a better looking bracket AND make it work better too!
So you may be asking, "What makes your brackets BETTER?"
We could have gone the route of making brackets that looked like everyone elses. Heck an upper link axle bracket can just be a piece of C channel steel with some bolt holes in it. Thats exactly the opposite approach we are taking. I personally like some thing with both ART and TECH. That is why we've decided to ask these critical questions to every bracket that we work on.
  • What are the advantages/disadvantages to an existing design regarding FUNCTION?
  • Could this bracket LOOK BETTER?
  • Can we make it AFFORDABLE?
  • Can we improve EASE of INSTALLATION?
  • Can we make it FIT most applications?
Obviously, sometimes its not necessary to reinvent the wheel, but can you imagine if vehicles still had wagon wheels today because no one asked the above questions. We approach every project like this and we may not always improve the existing designs.
I think we can make BETTER BRACKETS and we are excited to work with you guys to bring this to pass.
So, as we develop this line we'd like to ask... What do you specifically like or dislike about any bracket that you have purchased? Your feedback will be most valuable in bringing a better product to the market.
CHECK OUT ALL OUR BRACKETS HERE
Our first bracket - Lower Frame Link Bracket
With our new line of brackets, we want to introduce a better looking product that has that custom one-off look AND solve some of the issues that have plagued some of the generic brackets on the market, thus making them function better. Some common features that you'll see among our new brackets are: better access to grease fittings, bottom protection of the joint on lower link brackets, designs that make the bracket look like it was designed to be there from the beginning rather than just a piece of metal slapped on later, etc. Below are some of the highlights for this particular bracket that set it apart from all the others.
  • 2.625" mounting width with 9/16" bolt hole for common sized Cartridge Joints (Johnny, Flex, Ballistic, etc). Can be drilled out to larger hole size for 1.25" rod ends with spacers.
  • Made from 1/4" thick boxed steel plate for strength and impact resistance.
  • Grease fitting access on top to allow easy maintenance of your most abused joint. Design allows joint to be mounted grease fitting up.Other companies' frame brackets mount the grease fitting down, resulting in a broken fitting on the very impact.
  • Skid plate of bottom of bracket wraps around joint protecting it from direct impact and decreases premature wear on the joint. This leads to longer life and less replacements. Skid plate design does not restrict movement of joint.
  • Tapered sides allow bracket to be mounted at an angle on the frame without excess bracket hanging off the side. Not only does it look better and more natural to the frame, but it also means you have less bracket sliding on the rocks and getting in the way.
  • The STYLE of the bracket gives a unique, custom one-off look you'd get with a high dollar fabrication shop. No more brackets that look like modified pieces of angle iron or c-channel, but rather formed pieces of artwork to show off.
ARTEC INDUSTRIES
1-855-ARTEC99
Jeepforum COUPON: jeepforum
Follow us on
Quick Links:
ARTEC is offline
post #2 of 27 Old 09-16-2011, 12:20 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Next - Large 4-link Xmember Bracket for 1.75" tubing
This bracket allows for triangulated lower links that meet at a 1.75" OD tube crossmember between frame rails. This bracket is for use with large joints that have a 2.625" mounting width. This includes, but is not limited to, 1.25" rod ends (heims) with misalignment spacers, and rebuildable cartridge style joints with a 2.5" or 2.625" width (Johnny, Flex, Ballistic, etc). The hole size is 9/16" and can be drilled for larger sizes. The angles are set at 22 degrees each (44 degrees total) to allow use with our angled lower link axle brackets. This bracket is made from .250" thick steel and comes in six unwelded pieces that jig together for easy assembly. We recommend using heavy wall 1.75" tubing for your crossmember for maximum strength.
What sets ours apart from other similar products?
First, since lower links receive so much abuse from obstacles dragging across them, we've made the lower plate of this bracket cover most of the joint so that rocks aren't directly hitting the joint. This not only reduces the chance of joint breakage, but increases the life of the joint since it is not repeatedly being abused. You can save alot of money when you aren't having to replace joints all the time and that's the biggest advantage to this design.
Second, for those using greasable joints, the design of the top and side pieces allows easier access to the top of the joint where a grease zerk is usually located. Having a greasable joint does you no good when you can't access the grease fitting. Again, longer lasting joints means less money replacing them down the road.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #3 of 27 Old 09-21-2011, 12:59 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Next up - Lower Link Axle Brackets
Notice the skid plates built in under the brackets to protect the joints. Everytime I check out a vehicle I look at the lower joints and see them just chewed up by the rocks. That can't be easy on those joints and it'll definitely cause them to not last as long, let alone break on the trail. Thats alot of $$ to replace those when they could simply be protected.
Some other features: lots of drainage, 2.625" mounting width with 9/16 holes, 1/4" steel, available in 0, 10, and 22 degree angles, yada yada yada...
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #4 of 27 Old 09-23-2011, 06:44 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Dual 4-link Bracket
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #5 of 27 Old 09-26-2011, 02:05 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Another photo I didn't get up on Friday. Thanks for all the weekend orders on these.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #6 of 27 Old 11-22-2011, 06:12 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #7 of 27 Old 01-01-2012, 03:39 PM
VecoPlan
Bump for a great vendor, great products, and generally awesome guys. Thanks Artec!
I Peter 3:15 ... are you ready?
VecoPlan is offline
post #8 of 27 Old 03-28-2012, 03:44 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Here's some new brackets we cooked up...
Panhard (tracbar) mount for our Dana 60 trusses.
Frame side panhard (tracbar) mount.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #9 of 27 Old 03-28-2012, 05:13 PM
Brian86992
Any pictures of the dual 4 link on a TJ frame? Thanks.
Protect the Constitution
4 linked DD on coilovers
Brian86992 is offline
post #10 of 27 Old 03-28-2012, 06:55 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #11 of 27 Old 03-28-2012, 06:59 PM
Brian86992
Thanks Your artecindustries.com link is dead in your sig btw
post #12 of 27 Old 06-20-2012, 12:26 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
For all those who have been waiting for the adjustable inner frame link mount:
•One inch separation between each hole for adjustability.
•Floating top gusset allows any height frame.
•Frame plate add strength and a surface to weld bracket to with jigs for easy assembly.
•2.625" mounting width with 9/16" bolt hole for common sized Cartridge Joints (Johnny, Flex, Ballistic, etc). Can be drilled out to larger hole size for 1.25" rod ends with spacers. Can be easily modified for smaller joints
•Made from 1/4" thick boxed steel plate for strength and impact resistance.
•Grease fitting access on top to allow easy maintenance of your most abused joint.
We've got them on sale right now at 20% off!!! Click HERE for a link to the product
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #13 of 27 Old 01-08-2013, 06:08 AM
LA-Sahara
Interested in the lower link brackets, but your PMs are full.
LA-Sahara is offline
post #14 of 27 Old 01-14-2013, 10:18 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Sorry I didn't see this earlier. For some reason they didn't automatically renew my account so I didn't see any notification. You can send any questions thtrough this system. https://artecindustries.3dcartstores...tion=contactus
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #15 of 27 Old 03-22-2013, 10:11 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Introducing some of our new tabs:
Tub Tabs:
Flat Tabs:
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
KORE Universal 4 Link Brackets TJ Ken Vendor Display 21 12-28-2011 01:07 PM
Zone Offroad Body and Suspension Lift Kits, Brackets, Disconnects, and More Baseline 4x4 Vendor Display 10 11-28-2011 08:01 AM
You may not post new threads
