BDS XJ 3" LIFT!! HOOOOOK ups at Rockridge4wd!! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > BDS XJ 3" LIFT!! HOOOOOK ups at Rockridge4wd!!
New! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-08-2015, 05:36 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Check it out XJ guys!! I've got a GREAT lift for you! This is the 3" BDS suspension system!
This kit comes with two front Pro-Ride Coil Springs that are capable of withstanding full coil bind, transfer case drop, extended sway bar links, and a front track bar relocation bracket to properly center your axle. The rear is lifted with a 5/8" block and a long thin add-a-leaf to add height while not creating a harsh ride.
This is a great system for someone looking for a boost in ground and tire clearance without ******* out a ton of cash or making any serious modifications!
You can get this kit with the add-a-leaf OR if your leafs are in need of replacing, you can upgrade into full leaf springs. BDS Glide-Ride leaf springs will reduce axle wrap and create a more controlled and stable feel when towing. These springs are covered by the BDS No Fine Print Warranty.
Who's ready to step into some awesomeness?!! Contact me direct and i'll get you set up!!
Joel@rockridge4wd.com
Jeff@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
