Bds fox ipf 2.0 racing series shocks now available at rockridge54wd - Page 3 - JeepForum.com
post #31 of 126 Old 07-20-2013, 02:02 PM Thread Starter
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
APPLICATION SPECIFIC VALVING
Fox and BDS joined forces to custom valve each application to work perfectly with each BDS Suspension system. The basic shock design is based on Fox Racing Shox race products, but re-designed to turn your BDS equipped truck or Jeep into an offroad machine.
HEAT-REDUCING DESIGN
Cold-forged, metal-impacted 6061 T6 aluminum shock body dissipates heat three times faster than a conventional steel body shock. The 2.0 Performance Series shock runs as cool as a 2.5 diameter shock on the same application.
FOX Racing Shox formulated race shock oil developed for ultimate performance at variable temperatures.
TOUGH FINISH
CNC machined aluminum components
Heavy-duty 5/8" chrome shafts are induction case hardened to over 55 Rockwell C, virtually eliminating scratches caused by rust and debris.
FADE-FREE PERFORMANCE
The Internal Floating Piston (IFP) design separates shock oil from the high pressure nitrogen charged gas chamber, eliminating oil aeration and cavatation, while providing a predictable ride capable of handling the roughest conditions with fade-free performance.
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline
post #32 of 126 Old 09-09-2013, 01:43 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Needing NEW Shocks? BDS FOX IFP 2.0 RACING SHOCKS give you the on and off road ride you want all in one!
With an Easy Install with Bolt in Application. BDS FOX SHOCKS are specially Formulated race oil and Cold Forged, aluminum body capable of dissipating heat 3 times faster than your average shock! Gives this shock better overall performance and longevity. Dont hesitate contact ROCKRIDGE 4WD today for your very own Quote!
Like Us On FACEBOOK --> www.Facebook.com/rockridge4wd
post #33 of 126 Old 09-12-2013, 10:57 AM
Jeeper_YJ
1997 Cherokee XJ
4.5-6.5" both front and rear
Price?
'97 Cherokee, 99+ intake, 62mm TB, 703 injectors (new), k&n intake, Hypertech III, 180* stat (1/8" drilled hole), 2.5" manifold 2 tail pipe (Hooker Maxflow & hi flow cat), Perf header, 4.5" zone lift, 32" GY Dura Trac, Rear head rests. Comp cam "231" & Perf head (LS1 BIG valves 2.02/1.62). 3 row alum radiator.
Jeeper_YJ is offline
post #34 of 126 Old 09-12-2013, 11:04 AM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Originally Posted by Jeeper_YJ View Post
1997 Cherokee XJ
Price?
PM Coming to you!
Thanks so much
Erin
ROCKRIDGE 4WD
post #35 of 126 Old 09-17-2013, 12:31 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Looking for a Good Quality Shock that gives you both Onroad and Offroad ability? Contact ROCKRIDGE 4WD today for your BDS FOX SHOCK IFP Quote Today!
post #36 of 126 Old 09-24-2013, 12:53 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Looking for Good Off Road and On Road Shocks BDS FOX IFP 2.0 racing shocks are a great quality shock contact Rockridge 4wd today for your very own quote!
Click here to order now!
post #37 of 126 Old 09-25-2013, 05:29 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
BDS FOX IFP 2.0 Racing Series Shock! Contact Rockridge 4WD today for your very own Quote!
post #38 of 126 Old 10-09-2013, 12:22 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Do you want your Jeep to ride like a Cadillac? Do you want the ultimate riding experience? Then you need these BDS Fox Shocks! They are straight amazing!! Forum members get free shipping on these bad boys!!
Contact Erin@Rockridge4wd.com Today for your quote!
post #39 of 126 Old 10-12-2013, 03:38 PM
kylekae
Price for 4 shocks 06 lj 4 inch Bds lift? 30022
kylekae is offline
post #40 of 126 Old 10-14-2013, 10:14 AM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
PM on it's way!
Thanks so much
Erin
ROCKRIDGE 4WD
post #41 of 126 Old 10-15-2013, 12:08 PM
BamaJeepman21
Could I get a price on some 10" travel remote res? If ya'll have them. Thanks.
-Jack
BamaJeepman21 is offline
post #42 of 126 Old 10-15-2013, 01:24 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
These shocks are not remote resevoir. However I can look and see if they make them for your application. Do you do extended and collapsed measurments?
Thanks
Erin
ROCKRIDGE 4WD
post #43 of 126 Old 10-15-2013, 02:32 PM
BamaJeepman21
Thanks
Erin
ROCKRIDGE 4WD
Extended is 26.10" and collapsed is 16.10".
-Jack
post #44 of 126 Old 10-15-2013, 04:02 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
PM coming your way!
post #45 of 126 Old 10-30-2013, 01:13 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Need a little bit better ride in your Jeep? You need FOX 2.0 SERIES SHOCKS!
These will amaze you in your ride quality! Be able to go down dirt roads faster then ever before and not feel a thing! Take wash board roads or whoops faster then ever!
They are awesome!
Contact Erin@Rockridge4wd.com today for your quote!
You may not post new threads
