BDS 4.5" Long arm suspension kit for XJ!! GREAT DEALS on these kits at Rockridge4wd! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > BDS 4.5" Long arm suspension kit for XJ!! GREAT DEALS on these kits at Rockridge4wd!
New rockridge 4wd sales rep!!!FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 03-18-2015, 01:19 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Here it is XJ guys!! The BDS 4.5" Long arm suspension system!! Welcome to the LAST suspension system you'll every buy for your XJ!! CHECK IT OUT!
The BDS 4.5" XJ Long Arm system provides the best on and offroad capability you could ask for. By maximizing the length of both the upper and lower control arms, BDS has minimized caster change for optimum handling and minimized road forces transmitted ultimately to your seat for the best ride. To give you some idea, the lower arms are nearly bottomed out at just over 32" and the uppers at just over 28". This is about double the length of the factory control arms!
Although this XJ long arm system makes for a great daily driver, the true abilities of this system won' t be appreciated until you hit the rocks, dirt and mud. The 4-Link design maintains better axle control through wheel travel than any radius arm system because the upper to lower link relationship is not fixed, yet is tuned for optimum performance based on link length and operating angles. The control arm geometry is setup with the massive belly pan that incorporates the link mounts and is built to smash rocks. Believe it or not, this system is completely bolt on with no welding to the uni-body required!
BDS Pro-Ride Coil Springs, capable of withstanding full coil bind and a tuned rate lift the front. The rear is lifted with new Glide-Ride Leaf Springs and extended greasable shackles that really let the springs flex.
This system also incorporates BDS Ultimate sway bar disconnects for quick easy access to ridiculous wheel travel and stainless steel brake lines to handle it. Bump stop extension are included to limit compression and keep the tires out of the fenders on the trail. A front adjustable track bar with flex joint fits into the existing frame mount, so drilling of the taper is not required and will allow you to accurately center the front axle.
This system is available with both flex and standard control arm bushings, 5500 series or Fox 2.0 series shocks, and many other upgrades.
All BDS Suspension lift kits come with the security of knowing you purchased the finest lift kit in the aftermarket suspension industry. BDS backs their commitment to engineering reliable, quality 4x4 off-road Jeep and truck suspension products with their unique "No BS Hardcore Lifetime Warranty"
BDS is without a doubt, one of the TOP manufacturers in the business, and they're 100% made in the US!!
At Rockridge4wd, we take pride in our excellent pricing, QUICK shipping, OPEN communication and above all, GREAT customer service!
Contact me direct and i'll give you a DEAL on this incredible BDS suspension system!!
Joel@Rockridge4wd.com
Jeff@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
