BDS 2" SUSPENSION LIFT for JK 4DR!! DEALS INSIDE!! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > BDS 2" SUSPENSION LIFT for JK 4DR!! DEALS INSIDE!!
New rockridge 4wd sales rep!!!FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 03-24-2015, 04:56 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Here's a special deal for all the JKU guys out there!! BDS has a 2" coil suspension system designed SPECIFICALLY for your 4 DOOR!! Check it out!!
BDS has built a solid reputation for top quality suspension systems, so that is why BDS didn't stop with just offering a 2" spacer system like many other companies. This 2" coil spring lift system is built specifically for 4 door models and includes front and rear BDS Pro-Ride Coil Springs, bump stop extensions, Octocam Washers and BDS 5500 series shock absorbers. You also have the option of upgrading to BDS by Fox 2.0 Series mono-tube gas shocks for premium handling and ride control. Fixed swaybar links are included for Rubicon models with the factory disconnect system, for non-Rubicon models choose between BDS Ultimate Sway Bar Disconnects or JKS Quicker Disconnects to greatly improve suspension articulation when the terrain gets rough.
This is the perfect set up if you're looking to gain some clearance, add style to your JKU, maintain factory ride OR BETTER, and not spend a TON of cash!!
BDS is one of the top names in the industry, with a HUGE selection of suspension systems for a wide variety of vehicles! BDS also has the BEST warranty in the business.. HANDS DOWN!!
Contact me direct and i'll get you a great deal on this 2" BDS kit for your JKU!!
Joel@rockridge4wd.com
Jeff@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
