-   Vendor Display (http://www.jeepforum.com/forum/f43/)
-   -   Barnes 4WD Rear Coil Spring Relocation Kit (http://www.jeepforum.com/forum/f43/barnes-4wd-rear-coil-spring-relocation-kit-1233180/)
Barnes4wd 06-28-2011 02:45 PM
1 Attachment(s)
Attachment 254627
The Barnes 4WD Rear Spring relocation Kit can be used on either a TJ or LJ. This kit can be used to locate the upper coil spring in a vertical position or works great when stretching your wheel base. You can still use your factory or aftermarket bump stops with this kit. Welding and cutting will be needed and you will reuse the factory coil spring plate. Like all of our products this kit is laser cut and made in the USA. Kit includes parts for both rear springs!
http://www.barnes4wd.com/product_inf...oducts_id=2456
Barnes4wd 07-07-2011 03:07 PM
Get your springs were they should be!
Barnes4wd 07-13-2011 11:02 AM
Great way to stretch your wheelbase.
Barnes4wd 07-18-2011 07:39 PM
No need to wait for your parts!
Barnes4wd 07-25-2011 03:47 PM
Thanks for your business!
Barnes4wd 07-28-2011 07:06 PM
Let your springs work the way that they should
Barnes4wd 08-08-2011 07:06 PM
You guys have made this a big hit THANKS
Barnes4wd 08-17-2011 07:15 PM
Let your springs work like they should!
Barnes4wd 08-23-2011 06:01 PM
Thanks for making these a big hit!
Barnes4wd 09-01-2011 06:35 PM
Thanks for your orders!
Barnes4wd 12-15-2011 02:12 PM
These make great Stocking Stuffers!
The time now is 07:27 PM.
