Barnes 4WD GM 14 Bolt High Clearance Shave Cover - JeepForum.com
post #1 of 11 Old 06-28-2011, 01:59 PM Thread Starter
Barnes4wd
Barnes4wd's Avatar
The 14 bolt is a great axle. They are cheap, strong, easy to find and cheap to build. However they have always had one down fall, that huge lip on the bottom that get hung one ever thing on the trail. Barnes 4WD has come up with a solution to this issue. Our GM 14 Bolt 3/8 Shave Cover. This cover will give you more than 1 of ground clearance. Another thing that makes this a great shave cover is that you will not need to have your gears turned or perform a complicated welding or machining process that just adds more cost to your axle build. All that you will need to do is bolt the diff cover to your axle and cut off the extra lip. This can be done with simple tools that you have and you can do it yourself and we GUARANTEETHEM FOR LIFE! Like all of our diff covers they are made from 3/8 plate and machined flat after they are welded to insure that you will have a flat surface to mount to your axle. We do recommend using allen head bolts on our GM 14 Bolt Shave Cover.
http://www.barnes4wd.com/product_inf...oducts_id=2424
(828) 551-7616
Your order will ship in one business day or we pay the shipping.
Barnes4wd is offline
post #2 of 11 Old 07-07-2011, 03:06 PM Thread Starter
Barnes4wd
Barnes4wd's Avatar
This just might make the 14 bolt perfect!
(828) 551-7616
post #3 of 11 Old 07-13-2011, 11:01 AM Thread Starter
Barnes4wd
Barnes4wd's Avatar
Did not take long for these to catch on
(828) 551-7616
post #4 of 11 Old 07-18-2011, 07:37 PM Thread Starter
Barnes4wd
Barnes4wd's Avatar
Thanks for your weekend orders!
(828) 551-7616
post #5 of 11 Old 07-25-2011, 03:43 PM Thread Starter
Barnes4wd
Barnes4wd's Avatar
Hope that you had a great time wheeling this weekend.
(828) 551-7616
post #6 of 11 Old 07-28-2011, 07:04 PM Thread Starter
Barnes4wd
Barnes4wd's Avatar
We have got all the parts you need to make your 14 bolt just right!
(828) 551-7616
post #7 of 11 Old 08-08-2011, 07:05 PM Thread Starter
Barnes4wd
Barnes4wd's Avatar
Several people have asked about the thickness at the cut. It is about 3/8.
(828) 551-7616
post #8 of 11 Old 08-17-2011, 07:13 PM Thread Starter
Barnes4wd
Barnes4wd's Avatar
Thanks for your business!
(828) 551-7616
post #9 of 11 Old 08-22-2011, 06:52 PM Thread Starter
Barnes4wd
Barnes4wd's Avatar
All PM's returned
Thanks for your interest
(828) 551-7616
post #10 of 11 Old 09-01-2011, 06:33 PM Thread Starter
Barnes4wd
Barnes4wd's Avatar
Makes a 14 bolt just right.
(828) 551-7616
post #11 of 11 Old 12-21-2011, 02:47 PM Thread Starter
Barnes4wd
Barnes4wd's Avatar
Thanks for your orders
(828) 551-7616
You may not post new threads
