ARB TWIN COMPRESSORS NOW SHIP FREE! Available at Rockridge 4WD! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > ARB TWIN COMPRESSORS NOW SHIP FREE! Available at Rockridge 4WD!
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME New Wurton LED Pod Lights Brought To JF By Rockridge 4WD!
Unread 05-24-2012, 06:10 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Available at ROCKRIDGE 4WD!
ARB's new CKMTA12 twin on-board compressor kits were designed to fill the market need for a compact sized yet high-volume compressed air source to suit the high volume airflow needs of most air powered tools, and also to suit the actuation and control needs of the ARB Air Locker, and the harsh and demanding environment of the ARB Air Locker user.
FEATURES
Available in 12V (CKMTA12) or 24V (CKMTA24) models.
Constructed primarily of light weight, high strength, engineering grade
materials, including military and aerospace standard components.
Pressure switch controlled air manifold system regulates pressure between 9.3Bar [135PSI] and 10.3Bar [150PSI] suited to air tools and all ARB Air Locker equipped vehicles.
Highest air flow rate of any 12V compressor of its size on the market at 174LPM [6.16CFM].
High efficiency design consumes only 56 Amps at maximum air flow.
Built with sealed components for moisture and dust resistance.
Hard-anodized cylinder bores and PTFE (Teflon) impregnated carbon
fiber piston seals for reduced friction and maximum trouble free life.
Ducted IP55 sealed brushless DC cooling fan and anodized motor mounting brackets effectively dissipate heat from the motors, heads and electronics allowing for a 100% duty cycle (under room temperature conditions).
Anti-vibration / sound deadening is integrated into the mount.
Relocatable splash resistant air filter assemblies for cleaner, cooler air supply and versatile waterproof air intake positioning.
High density and high flow washable sintered bronze air filter elements.
Full wiring loom included for simplified installation and easy plug-in connectivity to Air Locker control solenoids. (Note: Air Locker Manifold Kit #171503 required to mount solenoids).
Equipped with dual heavy duty Maxi-Fuses for professional in-line circuit protection and true circuit redundancy in case of a fault.
Motors are water sealed, 100% ball bearing equipped (i.e., no bushings used), and feature a unique linear brush pre-load system for extra long life, low heat and quiet operation throughout the life of the unit.
Motors are internally thermal protected against extreme temperature damage.
Compressor pistons are equipped with a heavy duty European made cylindrical roller bearing.
Over-pressure safety valve equipped.
Sealed illuminated automotive grade dash switch included.
Fully serviceable and all replacement parts available.
EMF suppressed for use in proximity to sensitive electronic equipment.
CE and C-Tick compliant.
Engineered, built, and individually dyno-tested in Australia from local and imported components.
JEFF
SALES@ROCKRIDGE4WD.COM
Jeff@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote
Unread 07-13-2012, 01:09 PM   #2
Rockridge4WD
Vendor
2010 JK Wrangler
Dont' forget that you will need a compressor with your NEW ARB! Why not just get a twin Air Compressor for you locker as well as hook up some air tools if needed on the trail!! Check it out!!
Jeff
Sales@Rockridge4WD.com
Unread 04-01-2013, 05:26 PM   #3
Rockridge4WD
Vendor
2010 JK Wrangler
Get your Twin ARB Compressors!! Now in stock at ROCKRIDGE 4WD!!!
Contact Erin@Rockridge4wd.com
Unread 04-08-2013, 11:26 AM   #4
Rockridge4WD
Vendor
2010 JK Wrangler
ONLY 2 Left In STOCK!
Contact me today for your Quote
Derran@rockridge4wd.com
Unread 05-02-2013, 03:32 PM   #5
Rockridge4WD
Vendor
2010 JK Wrangler
Get your ARB compressor today!
