American Outlaw in stock at JeepHut - JeepForum.com
post #1 of 5 Old 02-11-2014, 01:00 PM Thread Starter
JeepHut
These are awsome lights that really give you a wide pattern of brilliant, clear light. Heavy-duty cast aluminum housing, UV and high impact resistant, hard-coated polycarbonate lenses. The sate-of-the-art optics and diode technology built into the blinder head lights give it a crisp beam with a wide even pattern. The solid-state design and rugged construction will last many times longer than a traditional sealed beam.
This kit includes the "Anti-Flicker" wire conversion for the JK. LUMENS : LOW BEAM = 1100 HIGH BEAMS = 1650
JeepHut is offline
post #2 of 5 Old 02-11-2014, 01:00 PM Thread Starter
JeepHut
This bolt on JK cold air intake will instantly provide your Jeep with more HP and gas mileage. Installs in under an hour using basic hand tools. Low maintenance, easy to clean & looks great. When used in conjunction with the JK exhaust - the X-TREME X-HAUST can add up to 3mpg. hwy, even with those 36's (not to mention a noticeable boost in power).
JeepHut is offline
post #3 of 5 Old 02-11-2014, 01:01 PM Thread Starter
JeepHut
This is it, these are them. The game changer, EZ-ON Door Pin Guides.
This amazing patented product does what we all need done, help getting your Jeep doors back on quickly & cleanly. No more door dance, scraping paint or cursing. It's easy on your back. Don't stress about the end of a great trail run or day at the beach, the E-Z - ON door pins will be there to get the job done. Their stainless steel construction will hold up to the elements and repeated use, and yes you'll take the doors off more.
1 set (2 pcs)
JeepHut is offline
post #4 of 5 Old 02-11-2014, 01:02 PM Thread Starter
JeepHut
http://www.thejeephut.com/brands/American-Outlaw.html
706-692-5488
JeepHut is offline
post #5 of 5 Old 06-18-2014, 12:26 PM Thread Starter
JeepHut
more in stock
706-692-5488
JeepHut is offline
You may not post new threads
