Alloy USA and Posi-Lok Cable Axle Disconnect Kits Dana 30 Front Axles - Page 4 - JeepForum.com
post #46 of 56 Old 02-19-2014, 08:31 AM Thread Starter
Baseline 4x4
Baseline 4x4's Avatar
1979 CJ5
Get your Posi-Lok 4x4 Cable Kit at www.baseline4x4.com
Baseline 4x4 Outfitters
Baseline 4x4 is offline
post #47 of 56 Old 03-11-2014, 01:05 PM Thread Starter
Baseline 4x4
1979 CJ5
Get your Jeep Cable Lock Kits at www.baseline4x4.com
post #48 of 56 Old 04-16-2014, 08:38 AM Thread Starter
Baseline 4x4
1979 CJ5
Free shipping on Jeep Posi Lok Cable Kits
post #49 of 56 Old 06-18-2014, 02:56 PM Thread Starter
Baseline 4x4
1979 CJ5
Great prices and free shipping on Posi-Lok Cable Kits at www.baseline4x4.com
post #50 of 56 Old 07-02-2014, 08:25 AM Thread Starter
Baseline 4x4
1979 CJ5
Free shipping on Jeep Posi-Loc Cable Kits at www.baseline4x4.com
post #51 of 56 Old 08-29-2014, 09:51 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Jeep Cable Lock Kit at www.baseline4x4.com
post #52 of 56 Old 09-23-2014, 09:12 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Posi Lok Kit at www.baseline4x4.com
post #53 of 56 Old 10-29-2014, 09:35 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Posi-Lok Kit at www.baseline4x4.com today!
post #54 of 56 Old 08-07-2016, 08:19 AM
curtis2010
1989 XJ Cherokee
Alloy USA Differential Permanent Cable Lock Kit
Imstalled one of these on my 89 XJ recently. This is the permanent lock version, not the cable lock version.
Works, but mine had a few issues. 1, thread for larger plug was roughly cut, had to lubricate and run in/out a few times to fix. 2, shaft which passes thru hole in fork had slight flare on end which had to be sanded down to pass thru hole in fork. 3, several misc small parts are included, presumably for capping off vaccum lines, but no reference made to them in instructions.
Pics to follow.
curtis2010 is offline
post #55 of 56 Old 08-07-2016, 08:25 AM
curtis2010
1989 XJ Cherokee
post #56 of 56 Old 08-07-2016, 08:31 AM
curtis2010
1989 XJ Cherokee
A very clean way to cap off the old vacuum lines is to use the 3 way connector where they terminate as a plug. To do that remove the connector, pull the connectors out of the plug (light colored tubes in pic. I cut hoses off before pic), fill plug ends with silicone, let set, reinstall plug. I secured mine with a cable tie just to make sure it stayed in place.
Alloy USA Dana 30 Front Axle Lockout Hub Conversion Kit Jeep TJ YJ XJ Baseline 4x4 Vendor Display 30 09-21-2012 08:30 AM
You may not post new threads
