Alloy USA and Posi-Lok Cable Axle Disconnect Kits Dana 30 Front Axles - JeepForum.com
post #1 of 56 Old 08-01-2011, 08:08 PM Thread Starter
Baseline 4x4
Baseline 4x4's Avatar
1979 CJ5
The Alloy USA® Differential Cable Lock Kit is a permanent replacement for the failure prone OE vacuum disconnect system. The kit allows you to engage and lock the front axle from inside the cab. A 1” pull of the cable ensures you will have four wheel drive when you need it for as long as the transfer case is engaged. The Differential Cable Lock Kit is more cost effective and easier to install than a locker or posi-trac system. Backed by a three year warranty.
450920 - Alloy USA Differential Cable Lock Kit, For 3-In To 6-In Lift, with Front D30 Axle, Jeep Wrangler YJ 1987-1995, Cherokee XJ 1984-1991
450900 - Alloy USA Differential Cable Lock Kit, with Front D30 Axle, Jeep Wrangler YJ 1987-1995, Cherokee XJ 1984-1991
450100 - Alloy USA Shift Fork, Cast Iron, For Use W/ Alloy USA or Posi Lok Differential Cable Lock Kit, Jeep W/ Front Dana 30 Wrangler YJ 87-95, Cherokee XJ 84-91
The 4x4 Posi-Lok System™ will fit the following applications:
1987 to 1995 Jeep® YJ Wrangler the Dana 30 vacuum actuated front axle
1987 to 1995 Jeep® XJ Cherokee the Dana 30 vacuum actuated front axle
The 4x4 Posi-Lok System™ is a permanent replacement for both the original equipment vacuum and electric axle engagement systems
The installation of this kit gives you direct control, of your 4 wheel drive system, from inside the cab
A one inch pull of the cable ensures you will have four wheel drive when you need it
Simple and easy installation
Note: This system is not a posi track or locker system
PSL920 - 4x4 Posi-Lok Vacuum Actuator Eliminator Kit, 3" To 6" Of Lift
PSL900 - 4x4 Posi-Lok Vacuum Actuator Eliminator Kit
PSL100 - 4x4 Posi-Lok Dana 30 Front Axle With Disconnect, Cast Iron Shift Fork
Baseline 4x4 Outfitters
Baseline 4x4 is offline
post #2 of 56 Old 08-12-2011, 08:52 PM Thread Starter
Baseline 4x4
1979 CJ5
Eliminate that vaccum actuated system with these Posi-Lock and Cable Lock systems
post #3 of 56 Old 08-19-2011, 02:05 PM Thread Starter
Baseline 4x4
1979 CJ5
Be sure your YJ's front axle is connected before winter.
post #4 of 56 Old 08-31-2011, 11:30 AM Thread Starter
Baseline 4x4
1979 CJ5
Positive engagement everytime with Posi-Lock Kits
post #5 of 56 Old 09-14-2011, 01:19 PM Thread Starter
Baseline 4x4
1979 CJ5
Get yours before the winter rush comes in.
post #6 of 56 Old 09-18-2011, 09:11 AM Thread Starter
Baseline 4x4
1979 CJ5
Fix those leaking vacuum actuators with these cable lock kits from Rugged Ridge and Posi Lock
post #7 of 56 Old 09-22-2011, 08:30 AM Thread Starter
Baseline 4x4
1979 CJ5
Upgrade your vacuum disconnect axle with these positive engagement kits from Posi-Lock and Rugged Ridge.
post #8 of 56 Old 10-17-2011, 07:23 AM Thread Starter
Baseline 4x4
1979 CJ5
Ensure a positive engagement of that 4 Wheel Drive System with these Vacuum Actuator Eliminator Kits from Rugged Ridge and Alloy USA.
post #9 of 56 Old 10-24-2011, 01:22 PM Thread Starter
Baseline 4x4
1979 CJ5
Time to check that vacuum actuator to make sure it is working like it should. These cable lock kits will ensure positive engagement of your front axle.
post #10 of 56 Old 12-05-2011, 05:07 PM Thread Starter
Baseline 4x4
1979 CJ5
Don't wait for a storm to fix your 4wd. Fix it before hand.
post #11 of 56 Old 01-18-2012, 11:20 AM Thread Starter
Baseline 4x4
1979 CJ5
Eliminate those problems associated with vacuum disconnet axle with a new Posi-Lock kit.
post #12 of 56 Old 01-28-2012, 01:22 PM Thread Starter
Baseline 4x4
1979 CJ5
Eliminate the problems associated Vacuum Disconnect Axles with these Disconnect Kits from Posi-Loc and Rugged Ridge
post #13 of 56 Old 02-15-2012, 08:29 AM Thread Starter
Baseline 4x4
1979 CJ5
Great kits to ensure your axle is engage for 4wd.
post #14 of 56 Old 02-16-2012, 01:34 PM Thread Starter
Baseline 4x4
1979 CJ5
Positive engagement of our disconnect style axle with these cable lock kits from Alloy USA
post #15 of 56 Old 03-06-2012, 07:57 PM Thread Starter
Baseline 4x4
1979 CJ5
Great kits to ensure your axle is engaged.
Alloy USA Dana 30 Front Axle Lockout Hub Conversion Kit Jeep TJ YJ XJ Baseline 4x4 Vendor Display 30 09-21-2012 07:30 AM
You may not post new threads
