-   Vendor Display (http://www.jeepforum.com/forum/f43/)
-   -   Alloy USA and Posi-Lok Cable Axle Disconnect Kits Dana 30 Front Axles (http://www.jeepforum.com/forum/f43/alloy-usa-posi-lok-cable-axle-disconnect-kits-dana-30-front-axles-1247500/)
Baseline 4x4 08-01-2011 08:08 PM
http://www.baseline4x4.com/images/ma...n/alloyusa.jpg
The Alloy USA® Differential Cable Lock Kit is a permanent replacement for the failure prone OE vacuum disconnect system. The kit allows you to engage and lock the front axle from inside the cab. A 1” pull of the cable ensures you will have four wheel drive when you need it for as long as the transfer case is engaged. The Differential Cable Lock Kit is more cost effective and easier to install than a locker or posi-trac system. Backed by a three year warranty.
http://www.baseline4x4.com/images/pr...ium/450920.jpg
450920 - Alloy USA Differential Cable Lock Kit, For 3-In To 6-In Lift, with Front D30 Axle, Jeep Wrangler YJ 1987-1995, Cherokee XJ 1984-1991
http://www.baseline4x4.com/images/pr...ium/450900.jpg
450900 - Alloy USA Differential Cable Lock Kit, with Front D30 Axle, Jeep Wrangler YJ 1987-1995, Cherokee XJ 1984-1991
http://www.baseline4x4.com/images/pr...ium/450100.jpg
450100 - Alloy USA Shift Fork, Cast Iron, For Use W/ Alloy USA or Posi Lok Differential Cable Lock Kit, Jeep W/ Front Dana 30 Wrangler YJ 87-95, Cherokee XJ 84-91
http://www.baseline4x4.com/images/ma...on/posilok.jpg
The 4x4 Posi-Lok System™ will fit the following applications:
1987 to 1995 Jeep® YJ Wrangler the Dana 30 vacuum actuated front axle
1987 to 1995 Jeep® XJ Cherokee the Dana 30 vacuum actuated front axle
The 4x4 Posi-Lok System™ is a permanent replacement for both the original equipment vacuum and electric axle engagement systems
The installation of this kit gives you direct control, of your 4 wheel drive system, from inside the cab
A one inch pull of the cable ensures you will have four wheel drive when you need it
Simple and easy installation
Note: This system is not a posi track or locker system
http://www.baseline4x4.com/images/pr...ium/PSL920.jpg
PSL920 - 4x4 Posi-Lok Vacuum Actuator Eliminator Kit, 3" To 6" Of Lift
http://www.baseline4x4.com/images/pr...ium/PSL900.jpg
PSL900 - 4x4 Posi-Lok Vacuum Actuator Eliminator Kit
http://www.baseline4x4.com/images/pr...ium/PSL100.jpg
PSL100 - 4x4 Posi-Lok Dana 30 Front Axle With Disconnect, Cast Iron Shift Fork
Baseline 4x4 08-12-2011 08:52 PM
Eliminate that vaccum actuated system with these Posi-Lock and Cable Lock systems
Baseline 4x4 08-19-2011 02:05 PM
Be sure your YJ's front axle is connected before winter.
Baseline 4x4 08-31-2011 11:30 AM
Positive engagement everytime with Posi-Lock Kits
Baseline 4x4 09-14-2011 01:19 PM
Get yours before the winter rush comes in.
Baseline 4x4 09-18-2011 09:11 AM
Fix those leaking vacuum actuators with these cable lock kits from Rugged Ridge and Posi Lock
Baseline 4x4 09-22-2011 08:30 AM
Upgrade your vacuum disconnect axle with these positive engagement kits from Posi-Lock and Rugged Ridge.
Baseline 4x4 10-17-2011 07:23 AM
Ensure a positive engagement of that 4 Wheel Drive System with these Vacuum Actuator Eliminator Kits from Rugged Ridge and Alloy USA.
Baseline 4x4 10-24-2011 01:22 PM
Time to check that vacuum actuator to make sure it is working like it should. These cable lock kits will ensure positive engagement of your front axle.
Baseline 4x4 12-05-2011 05:07 PM
Don't wait for a storm to fix your 4wd. Fix it before hand.
Baseline 4x4 01-18-2012 11:20 AM
Eliminate those problems associated with vacuum disconnet axle with a new Posi-Lock kit.
Baseline 4x4 01-28-2012 01:22 PM
Eliminate the problems associated Vacuum Disconnect Axles with these Disconnect Kits from Posi-Loc and Rugged Ridge
Baseline 4x4 02-15-2012 08:29 AM
Great kits to ensure your axle is engage for 4wd.
Baseline 4x4 02-16-2012 01:34 PM
Positive engagement of our disconnect style axle with these cable lock kits from Alloy USA
Baseline 4x4 03-06-2012 07:57 PM
Great kits to ensure your axle is engaged.
The time now is 10:14 PM.
