97-06 Jeep TJ Wrangler Bowless Soft Tops with Tinted $364.95 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > 97-06 Jeep TJ Wrangler Bowless Soft Tops with Tinted $364.95
Huge Soft top SaleSYE Kits from CCOR! 706-207-4140SALE PRICING, Specials, Huge Savings Alloy USA and Posi-Lo
Unread 03-04-2011, 03:26 PM   #1
Baseline 4x4
1979 CJ5
The Rampage frameless soft top installs over the original equipment factory roll bar for a snug fit without the need for additional bows or support hardware. This unique design allows for larger side windows and improved visibility with removable side and rear windows that quickly convert the soft top into an open Safari top. Windows use heavy duty molded tooth zippers and are easily replaced or removed and stored in a special separation panel between the ceiling and roof top which is concealed and protects the windows from scratches or puncture. The fastback style offers improved aerodynamics and a quieter ride than factory bow style tops.
Factory grade materials & colors
DOT Compliant Windows with privacy tint
Weatherproof Attaches to factory belt rail system and windshield channel - Heat Sealed Seams & Windows and Marine grade molded tooth zippers
Replaceable Components including side & rear windows with heavy duty molded tooth zippers optional front window frames and Door Skins
Exclusive Rampage interior storage pockets for both driver & passenger
NOTE: Requires Windshield channel, factory soft top door surrounds and tail gate bar. If the soft top is replacing a hard top application, these parts are required and can be purchased separately. Half Door Models reuse factory upper door frames and skins.
Fits: 1997-2006 Jeep TJ Wrangler
Free Shipping
Baseline 4x4 Outfitters
Baseline 4x4 is online now   Reply With Quote Quick reply to this message
Unread 03-04-2011, 05:24 PM   #2
ccbruin
Do you make one for YJs with the family roll cage?
ccbruin is offline   Reply With Quote Quick reply to this message
Unread 03-05-2011, 09:47 PM   #3
midnight_f150
do you make upper door skins?
midnight_f150 is offline   Reply With Quote Quick reply to this message
Unread 03-05-2011, 10:11 PM   #4
rdsk8ter
1982 CJ7
x2
x2 for yj
rdsk8ter is offline   Reply With Quote Quick reply to this message
Unread 03-05-2011, 10:26 PM   #5
igrok
Is this the Sailcloth top?
Common sense is surprisingly, not that common.
igrok is offline   Reply With Quote Quick reply to this message
Unread 03-06-2011, 08:18 AM   #6
Baseline 4x4
1979 CJ5
These are only available for the TJ Wranglers at this time. This is made of a factory grade soft top material. We do not have these available in Sailcloth Material at this time.
Unread 03-06-2011, 05:25 PM   #7
Streetbyker13
How much to add on a windshield channel?
Streetbyker13 is offline   Reply With Quote Quick reply to this message
Unread 03-07-2011, 02:23 PM   #8
Baseline 4x4
1979 CJ5
We do not have access to the factory windshield channels. You will need to contact your local Jeep Dealer.
Unread 03-06-2012, 08:42 PM   #9
tayzoid1
Do you have the part number for this top in black diamond with door skins?
tayzoid1 is offline   Reply With Quote Quick reply to this message
Unread 03-06-2012, 08:43 PM   #10
tayzoid1
Sorry. Thought i saw 2012 on the date. Just realized it was 2011. Sorry for the dead thread revival
Unread 03-08-2012, 11:59 AM   #11
Baseline 4x4
1979 CJ5
Not a problem. I sent you a PM with some information Let me know if you have any questions.
Unread 03-11-2012, 11:36 AM   #12
Baseline 4x4
1979 CJ5
Instock, ready to ship and rebates are currently available.
