97-06 Jeep TJ/LJ SPOD - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > 97-06 Jeep TJ/LJ SPOD
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! 2 door JK Recruit Half hardtop Kits Now available!
Unread 07-22-2015, 11:37 AM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Hey guys and gals. If you thinking of adding multipule electronic accessories then you should check these out! This kit comes with all the required mounting brackets and hardware and it's pre-wired and ready for install! The best part about the spod is the LVCO "low voltage cut off" This will detect when your battery get's to 10v and cuts off the system then when your back up to 12v the system cut's back on! So no more dead jeeps due to leaving LED lighting on or any other electronics you may be running! The kit includes Switch panel, header, six Contura switches, 2 Red, 2 Amber and 2 Green actuators (installed and pre-wired), two piece Wire Harness set with 8 multi color leads utilizing 18 gauge wires. Each end has an automotive connector made by Deutsch. Email me today for the best pricing! Eric@rockridge4wd.com
sales@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
