97-06 Jeep TJ 3" lift kits - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > 97-06 Jeep TJ 3" lift kits
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi50" SINGLE ROW PANDEMIC LED Light bar FEATURES 4D Opt
Unread 06-23-2015, 11:43 AM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
The 3" lift system from zone is a great way to get you TJ to clear those 33" tires and get more wheel travel without having to do and major modifications to your Jeep! The springs are a true 3" lift spring so you wont have to deal with a spacer!!! The kit comes with new front extended sway bar links with nice urethane bushings to help with any body roll. A track bar relocation bracket is included to make sure you keep you axle centered under your TJ. A 1" t-case drop is also included to correct drive line angles while reducing ground clearance as little as possible! Top that off with 4 hydro shocks that provide a nice smooth ride on and off road! this is a great kit that wont kill you pocket book so shoot me an email for the best pricing!!!
Eric@rockridge4wd.com
sales@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
