8.8 Swap Kit w/ TRUSS for Jeeps - Page 17 - JeepForum.com
post #241 of 347 Old 02-13-2013, 10:14 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
If you are thinking about getting some of ours parts, NOW would be a great time to do it. 15% off all ARTEC made products but HURRY, its over after Friday.
ARTEC INDUSTRIES
1-855-ARTEC99
Jeepforum COUPON: jeepforum
Follow us on
Quick Links:
ARTEC is offline
post #242 of 347 Old 02-14-2013, 12:40 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
LAST TWO DAYS of the SALE!!!
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #243 of 347 Old 02-19-2013, 07:05 AM
FKemp3
Has anyone else run into the install problem with a Currie adjustable trac bar? Width measured via the instructions is 1.6, Currie trac bar is 2.1. Not enough material in the jig to make the adjustment, think I am going to canibalize the Currie mount and weld it to the truss.
FKemp3 is offline
post #244 of 347 Old 02-19-2013, 07:08 AM
KyBoy1991
I could be wrong here, but doesn't the track bar need to move at each end? and welding it would eliminate this from happening would it not?
KyBoy1991 is offline
post #245 of 347 Old 02-19-2013, 07:46 AM
FKemp3
Yes, it needs to move.. Talking about the distance between the mounts. The Currie adjustable trac bars bushing is 0.5 wider than stock, and there is not enough material on the jig to pull it out and make that adjustment though
FKemp3 is offline
post #246 of 347 Old 02-19-2013, 07:46 AM
lateralus3
1994 ZJ
I had to grind metal off the shock mounts to fit the shocks and I had to grind downbthe bushing and metal sleeve on my trackbar in order to fit it in the bracket
Jacob
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED
lateralus3 is offline
post #247 of 347 Old 02-19-2013, 07:49 AM
KyBoy1991
I would contact Artec and let them help with this. They may be able to provide a laser cut plate to match and you just cut off the existing one and weld this in it's place. To me it would make more sense to have a plate that's double the thickness at the bottom pushing the upper part open by .5" since the material is about 1/4" anyway. This could be the first encounter with the issue, but I'd think they would help you out.
I too had to grind some material off the shock mounts, as the bracket was hitting the shock body...or the neck of my shock wasn't long enough to reach into the bracket and allow for mounting in the hole. No biggie though. I also ground down the metal bushing a tad in one of my control arms, as I believe the material warped slightly during welding. But that's my fault.
post #248 of 347 Old 02-19-2013, 10:00 AM
Ben
I agree that they should give the option of stock OR aftermarket track bar width.
When I assembled mine, getting that mount to sit nice at 2" just wasn't happening, which is a bummer.
Ben is offline
post #249 of 347 Old 02-19-2013, 10:05 AM
FKemp3
What did you do to address it?
FKemp3 is offline
post #250 of 347 Old 02-19-2013, 10:16 AM
Ben
Decided to keep the stock trackbar until I can chop all that off and triangulate the uppers.
Ben is offline
post #251 of 347 Old 02-19-2013, 10:26 AM
alabamaboy54
TJ 8.8 swap/truss
Could you please pm me what price you guys could give me on the tj 8.8 truss kit shipped to 36606? Looks like a killer product, definitely interested as I will be doing an 8.8 swap in a few weeks
alabamaboy54 is offline
post #252 of 347 Old 02-19-2013, 09:26 PM
2002TJX65
Go on their website, you will get a quote there.
03 Rubicon: Build in Progress
02 TJ: Built and totaled
86 CJ7: Sold
2002TJX65 is offline
post #253 of 347 Old 02-19-2013, 09:50 PM
sjones26573
x2. You're not going to get some special deal.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #254 of 347 Old 02-19-2013, 09:56 PM
Ripper3494
just out of curiosity do you guys plan to build anything to box the truss to make it a little sturdier? i run a pretty high torque application and Iím starting to bend the top plate of the truss. its a great sturdy project but once you break 400ft/lbs in 4 low it starts to cause havoc.
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #255 of 347 Old 02-19-2013, 09:58 PM
sjones26573
I find this amazing.
Jeep-Owner.com
Barnes 4wd Axle Truss Barnes4wd Vendor Display 56 01-12-2012 11:44 AM
You may not post new threads
