76-86 Jeep CJ5 and CJ7 ignition - JeepForum.com
post #1 of 4 Old 06-02-2017, 06:44 AM Thread Starter
ididit
Vendor
Instead of getting a ordinary key in your ignition column, why not go with an Id Touch system!
Check it out right over here:
http://www.ididitinc.com/i-25049820-...tegory:1341772
The system has a number of innovative features and the button comes pre-installed in the column, if you need it to be...
If you have any questions, please let me know.
ididit is offline
post #2 of 4 Old 06-02-2017, 10:37 AM
deminimis
Here's the forum for post like this. Thanks. http://www.jeepforum.com/forum/f43/
'15 Ram 5500 Laramie Crew 4x4 for towing (the only way I can get my '86 CJ7 over 70mph)
deminimis is online now
post #3 of 4 Old 06-02-2017, 07:57 PM
Skerr
*choke* *choke* $740.00!? Do you really understand your target audience?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4 of 4 Old 06-03-2017, 04:38 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Interesting, Summit sells it for $666.00
Here is how it works:
Ididit Touch-N-Go keyless ignition systems give you the most advanced keyless ignition technology at the tip of your finger. The is the industry's first touch sensitive start system and features a 22mm aluminum button (25mm with column mount) with multi-color interactive LED lights that always let you know what mode it's in. Touch once and the system simulates the accessory position, touch twice and the system is in the on position, touch three times while pressing the brake pedal starts the car. Three rapid touches will turn the system off and stop the engine. There are no moving components to wear out, ensuring years of outstanding performance. This system can be used as a simple start button system or you can utilize more advance functions, such as keyless entry. Just stick your programmable key fob in your pocket or wallet and the system will sense your approach, automatically unlocking your door as you get close and locking it up as you leave (the system only responds when the key fob is in range). For added safety, this system can also be programmed to turn on your dome lights as you approach and includes a built in valet switch that allows you to override the system in the event of a dead key fob. Touch-N-Go systems are available for most ididit tilt steering columns and can replace your stock in-dash ignition. Made in the USA.
I think it fits right in the same position of your key switch. But it doesn't lock the column.
I haven't seen any pictures of it installed.
Security? I doubt that you couldn't defeat this system in less than a minute with a couple of wires under the hood and it doesn't lock the steering column.
But my Prius has this system, I don't need it in my jeep.
This would be closer to the "keyless" starter I would install in my jeep.
They do sell a lot of cool steering column stuff though.
John Strenk is offline
You may not post new threads
