6061 T6 Aluminum Wheel Adapters 5x4.5 to 5x5 (Allows JK Wheels on YJ, TJ, XJ) - JeepForum.com
post #1 of 6 Old 12-22-2011, 09:38 PM Thread Starter
Baseline 4x4
Baseline 4x4's Avatar
1979 CJ5
These hub centric spacers / adapters move your wheels out to help fit wider tires and give your vehicle a wider track and improve stability. Constructed of double anodized black extra thick 6061T6 aluminum for long life and extra corrosion resistance. All hardware is grade-8 for extra strength. Each part number comes as a spacer pair. Included are 10 pre-installed grade-8 wheel studs and 10 lug nuts.
15201.11 - Wheel Adaptor Pair, Black, 5 On 4.5 To 5 On 5 Bolt Pattern, 1.375 Inch Thick, 1997-2006 TJ Wrangler, 1987-1995 YJ Wrangler, 1987-2001 XJ Cherokee
Baseline 4x4 Outfitters
Baseline 4x4 is offline
post #2 of 6 Old 12-27-2011, 07:17 AM Thread Starter
Baseline 4x4
1979 CJ5
Wheel spacers allow you to adjust your tire width to give the clearance and stance you are looking for.
post #3 of 6 Old 01-01-2012, 08:52 AM Thread Starter
Baseline 4x4
1979 CJ5
Wheel Spacers from Alloy USA are made of 6061 T6 material for strength
post #4 of 6 Old 01-04-2012, 06:08 PM Thread Starter
Baseline 4x4
1979 CJ5
Wheel spacers give your Jeep the stance needed for additional clearance for those critical suspension components.
post #5 of 6 Old 01-05-2012, 12:23 PM Thread Starter
Baseline 4x4
1979 CJ5
Alloy USA Wheel Spaces are made from 6061 T6 aluminum and use grade 8 hardware to provide you with optimum performance
post #6 of 6 Old 04-05-2012, 06:17 AM Thread Starter
Baseline 4x4
1979 CJ5
Rugged Ridge Wheel Spacers and Adapters available at discount prices.
Barnes 4WD YJ Stubby Bumper Steel or 6061 T-6 Aluminum Barnes4wd Vendor Display 16 01-11-2012 03:20 PM
You may not post new threads
